What else should I ATAP when spraying?
Old Jan 3, 2002 | 04:06 PM
C5Noir's Avatar
C5Noir
Default What else should I ATAP when spraying?
Here's a list so far:
Ignition Time Advance
O2B1S1
O2B2S1
RPM
KR
Misfire
PWB1-injector pulse width Bank 1
PWB2-'' '' '' Bank 2
What else should I look for. I know that I want 0 KR across the board and keep my O2's from the lean area but these two go hand in hand. Thanks
Old Jan 3, 2002 | 04:28 PM
C5Cemo's Avatar
C5Cemo
Default Re: What else should I ATAP when spraying? (C5Noir)
Hey Levi,
You could also look at intake manifold pressure...you can calculate how much boost you're pushing through her by comparing NA Vs. N2O figures :D
Old Jan 3, 2002 | 09:31 PM
intel55's Avatar
intel55
I look at:
o2b1s1
o2b2s1
KR
RPM
TPS <--- to know when I am WOT
misfire on occasion... :cheers:
Old Jan 4, 2002 | 01:05 AM
geekracer's Avatar
geekracer
You might add Throttle position or possibly IAT maybe the system date and time.
If you're running a dry system I would be curious what the IAT does when you spray.
Also be aware that the more parameters that you poll the slower the polling period will be. Have fun with the autotap :cheers:
Old Jan 4, 2002 | 04:53 AM
intel55's Avatar
intel55
Default Re: What else should I ATAP when spraying? (MMarquez)
exactly why you want to have a short short list so you can catch all the lil zigs on the o2's and KR when running spray. Make sure the refresh is set to high (default). :cheers:
Old Jan 4, 2002 | 06:04 AM
Austrian Vette's Avatar
Austrian Vette
Default Re: What else should I ATAP when spraying? (intel55)
I look at:
o2b1s1
o2b2s1
KR
RPM
That´s what I look at, also!! :cheers:
I do have an Autometer led display installed for the 02 readings now, so I have the o2 readings under control all of the time.
Michael
Michael
Old Jan 4, 2002 | 09:23 AM
rwj383's Avatar
rwj383
hey, C5Noir;
seems this list is getting around fast!! i gave this list over on LS1.com nitrous forum last night. i forgot to mention that you will want either TPS or Cell# parameter to know when you're in WOT. Cell 22 is WOT. as far as the other concern about having too many parameters, well, it is true that the more you have the slower the refresh rate WHILE YOU DRIVE. the fact is, if you are recording your trace (which is the whole point), when you go back and study your trace and read each frame, you will have all the data there, regardless of the # of parameters you monitor. real time shouldnt matter then.
Old Jan 4, 2002 | 10:18 AM
shftn6's Avatar
shftn6
ttt
To What else should I ATAP when spraying?
