When do you change the engine mounts?
Old Aug 28, 2008 | 10:25 AM
RobertEarl's Avatar
RobertEarl
Default When do you change the engine mounts?
I have noticed recently that when I either let off of the gas or I put the pedal down, the top of my shifter ( MN6 ) moves from side to side almost 1/4 of an inch. I believe that this is due to the motor mounts. ( Can't really think of anything else it would be. ) When is it to much and I should change them out.
Also to those of you that have done this, is it a pain in the a## with headers on the car??
Reb
Old Aug 28, 2008 | 10:54 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Reb,
Is this in gear or just rev'ng the engine in netrual?
Eric D
Old Aug 28, 2008 | 12:00 PM
RobertEarl's Avatar
RobertEarl
This is in gear driving down the road.
Reb
Old Aug 28, 2008 | 12:36 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Check out the rear diff mount. These go bad sometimes, which can cause the same issues.
Randy
Old Aug 28, 2008 | 12:38 PM
vsocks1's Avatar
vsocks1
Randy
I have a rear diff mount from a 8000 mile 2003 Z06 in great condition if needed. Let me know and we can work out a price!
Old Aug 28, 2008 | 06:01 PM
Eric D's Avatar
Eric D
Reb,
I would suggest getting the car in the air and taking a very close look at all of the torque tube attach points front and rear. You should not see any movement of the shifter like you described. Has there been any work done recently that would have involved the removal of any of the driveline?
Eric D
To When do you change the engine mounts?
