any pointers on header install
Old Aug 28, 2008 | 10:20 PM
erics1's Avatar
erics1
Default any pointers on header install
Im going to put a set of 1 7/8" arh headers this weekend any pointers to make the job go smooth also where is a good place to place the jack stands the car will be on them a week or so, im also installing aa pro charger Is there something better than jack stands I dont have room for a big lift..
Cool thanks
Eric
Old Aug 29, 2008 | 12:21 AM
earnhardtJR's Avatar
earnhardtJR
If you want to wait for next weekend, you could order this and make your job go a lot smoother-
www.kwiklift.com
I am 95% sure that I will get one for my tiny garage... I am sick and tired of having no room to jack a car up and no room to move should the car decide to fall off the jacks. Others on this forum have had great success with this lift.
Old Aug 29, 2008 | 12:24 AM
02gt350's Avatar
02gt350
first off. get 1 3/4 headers. those are to big if you have a stock 346
2nd. they go in from top. remove the valve covers, oil filter and alternator. they will fall right it. put the O2's in once they are in, or they will never fit. i tired
Old Aug 29, 2008 | 12:27 AM
Jnape's Avatar
Jnape
Cool thanks
Eric
Not to be a D_IC_k but if jackstands are your primary issue, F/I install and tune are way beyond......
Old Aug 29, 2008 | 08:02 AM
erics1's Avatar
erics1
I havn't jack up the car yet looked under and just saw flat sheet metal.. as far as the pro charger its laid out on my bench. With these things on paper that say 1.
2.
3.
and I have a tuner who builds chevy ss trucks that beat zo6 s so thats why the f/i have a nice day D
Old Aug 29, 2008 | 09:01 AM
Bigstik's Avatar
Bigstik
Don't know about most, but I had to put the drivers side header in from the bottom. You can do it from the top, put you have to lift the motor an inch or two.
One tip is to make sure you get the car a good 3' off the groud if you decided to install from the bottom.
Old Aug 29, 2008 | 10:00 AM
vsocks1's Avatar
vsocks1
I installed ARH 1-3/4 and they both went in from the bottom. Didn't even need to remove starter. Gotta remove alternator only - no valve covers.
Old Aug 29, 2008 | 10:15 AM
slothy's Avatar
slothy
ya same, both from bottom - valve covers stayed on and remove alt, helps to have a 2nd hand to move wires outa the way on the passenger side.
Old Aug 29, 2008 | 10:16 AM
slothy's Avatar
slothy
i had mine about 2feet and had plenty of room
Old Aug 29, 2008 | 03:54 PM
02gt350's Avatar
02gt350
odd, i nev er removed the starter. and i think going from teh top on your feet is better than laying on your back working with no room. but thats just me. and it takes a total of 15 min to pull teh alternator and valve covers
Old Aug 29, 2008 | 06:03 PM
erics1's Avatar
erics1
Cool thanks for the options
Old Aug 29, 2008 | 06:21 PM
tech2262's Avatar
tech2262
go to this website its very helpful http://www.cajundude.com/c5techhome.htm
Old Aug 29, 2008 | 06:55 PM
20vette0107fatboy's Avatar
20vette0107fatboy
They go in from the bottom.Real easy.Did mine a few months ago.Just remove your alternator and i removed my coil packs.Makes things alot easier.......No need to remove the starter.
Old Aug 29, 2008 | 07:14 PM
Uncle John's Avatar
Uncle John
More like 20" or so.
Old Aug 29, 2008 | 10:19 PM
erics1's Avatar
erics1
hey thanks alot way cool site
Old Aug 31, 2008 | 11:29 AM
erics1's Avatar
erics1
Default got em on pita
passenger side I had to remove starter and lift the engine because of the pressurized a/c line no way from the bottom had to go down from the top cajun site was very helpful thank you all who replied I put 1 7/8 with a 3" cross pipe used the stock titainium exhaust. nice mello sound at idle and then comes to life. alright Ill bet the a&a procharger will be a much easier install than them headers were. I better get started. Later Eric
To any pointers on header install
