Do my Dyno #s look low?
Old Aug 30, 2008 | 03:50 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Originally Posted by nickolbag
I had a friend do the same exact thing and it made the exact same numbers. The sheets looked identical. I know it is "understood" that gears will rob some power on the dyno though.
Thats weird....I have seen many guys dyno lower with 4.10s from stock OEM with no other changes. I have seen many guys put down higher numbers when swapping back to 3.42s when the 4.10gears were too much for their new setup.
to the OP, given you are dynoing through 4.10s, figure your over 400 without them. 400-415 is the normal HP range with TSP heads
Old Aug 31, 2008 | 04:57 AM
sikpuppy's Avatar
sikpuppy
St. Jude Donor '08
Originally Posted by J.R.
The previous post re: Mustang Dyno is correct (Mustang Dyno's tend to post numbers that are approx. 10% lower than DynoJet 248). Dynapack's at your horsepower range tend to be very close to DynoJet numbers.
If you could post dyno sheet I am sure that some of the more knowledgeable persons on this forum could provide you with additional information.
I don't quite agree with this but I may just be real stupid.
IF you use a Mustang dyno or a Dynojet, it doesn't matter which as long as the setup takes into account temp, elevation, etc, etc, to arrive at the corrected SAE horsepower. Here may be a few HP differnece between a Dynojet and Mustang, even if both set up correctly but 10% difference?? Get real. If that is the case then my stock block, bolt on only '99 FRC (God rest it's soul) put down 371RWHP on a Mustang and by the 10% statement it should show over 400RWHP on a Dynojet?? Don't think so 'cause it was done on both and the Dynojet, properly set up, showed exactly 7rwhp higher than the Mustang which is less t han 2% variance. The point is,a dyno is only as accurate as the tuner is good. It all depends on the tuner no matter what type of Dyno you use. If they aren't set up right, not calibrated for SAE numbers, then it just ain't accurate no matter how you slice it. Dynos are, as stated earlier, a tool. Track it and get numbers from the TRACK 'cause that's where it's at.
And just my $0.02 worth, Thunder seems to have missed the boat on your tune because you should be making at least 420RWHP. Mine made 460.5RWHP(Dynojet, ASE corrected) and 451RWHP (Mustang dyno, ASE corrected) with just a little more head work than you have (check my sig).
Get another tune and then let us know and TAKE IT TO THE TRACK!!!!
Old Aug 31, 2008 | 08:30 AM
C5XTASY's Avatar
C5XTASY
Originally Posted by 02gt350
X2
dyno numbers are a tool for tuning..that is it. and dont always look at peak HP and TQ. area under curve is more important to me.
Old Aug 31, 2008 | 09:18 AM
VIPERBLUELX's Avatar
VIPERBLUELX
That's not entirely accurate. Mustang Dyno's are load bearing based on the weight of the car and if they haven't been "tweaked" then they always show lower numbers. Now that doesn't mean that the dyno operator hasn't added in a "correction" factor to try to make the dyno numbers more in line with dynojet numbers because I've seen that at some shops.
