Error codes1221 1222 1248
Old Aug 31, 2008 | 04:21 PM
DD04C5's Avatar
DD04C5
Default Error codes1221 1222 1248
I checked the codes and these keep poping up c1221h c1222h c1248h is this a bad thing? Codes 10pcm 1time 28tcs 3times, Thanks
Old Aug 31, 2008 | 04:41 PM
DD04C5's Avatar
DD04C5
cleared all codes 1 comes back every time I start it and it idles PO174,10PCM,
Old Aug 31, 2008 | 06:02 PM
c5Cruiser's Avatar
c5Cruiser
From: Corona CA - "An Armed Society is a Polite Scociety"
http://www.stengel.net/diccodes.htm
Old Aug 31, 2008 | 06:48 PM
DD04C5's Avatar
DD04C5
Thank You Greatly for the web site info,I will check to see if can find the problem tomorrow.
Old Aug 31, 2008 | 09:38 PM
DD04C5's Avatar
DD04C5
went out tonight and checked for leak at MAF,had a clamp a little loose,tightened up clamp P0174 code gone but now have P0300 code active,after engine runs about 60-90 seconds,engine idles good until code pops up,then starts running rough.10PCM-P0300 is a misfire code,makes no sense that it idles good and then rough after a short time,you thick that it would be rough from the get-go.
Old Aug 31, 2008 | 09:48 PM
p_dubya's Avatar
p_dubya
sounds like you're having a harder time with your header install then I did!
Double check that all of your plugs are tight and none are cracked. Double check that you didn't break any of the plug wires. Double check that all the wires 'clicked' on the plug and you got two (2) 'clicks' when you put the wires on the coil. Double check that have at least 3 beers when you're done.
Old Aug 31, 2008 | 10:16 PM
DD04C5's Avatar
DD04C5
yea, I'am having a few more problems that I planed on.Worked on heavy equipment for 35 years,and my own auto's that long. Wished I would have had LG installed headers.This has been one big project for sure! I do appreciate all of the help from everyone. Thanks
To Error codes1221 1222 1248
