dynatech supermax install help...
Old Aug 31, 2008 | 07:01 PM
1320IN9's Avatar
1320IN9
Default dynatech supermax install help...
just about finished with the header install and the 02 sensor extentions that come with the kit seem too short so i made them longer and soldered the wires together and put them back in the plastic wraping but i seems there is no place to route them with out the wires basicly laying down on the headers and i dont want to burn/melt any of my wires or have a fire, so where is the best spot to run the wires... thanks
Old Aug 31, 2008 | 07:22 PM
casslaw's Avatar
casslaw
you can route them right along the plate that bolts just above the headers, and use the small keepers (the ones that many people use to route large wires or hoses) and a small self tapper to keep the wires away from the headers. I'm sure there are other ways as well.
Old Aug 31, 2008 | 07:56 PM
1320IN9's Avatar
1320IN9
i will give that a try, still open to other ideas.
Old Aug 31, 2008 | 10:27 PM
B Taylor's Avatar
B Taylor
St. Jude Donor '08
Too short was my first impression, but I was able to move them aft 4-5 inches in the sames routing location, believe I may have cut a tie wrap or two. I created a couple of new tie wrap points, along with drilling one hole in the aluminum sheet on the bottom edge close to the point where the cables crossed going to the O2 sensors. The hole made a nice point to attach a tie wrap.
To dynatech supermax install help...
