Some quick emergency help needed!!
UPDATE: :Success,,had to get a little creative,,SEE POST 12
Those directions really sped the process up. By the way just wondering the female plug in ,does it hafe only 2 wires (purple and white) Im wondering if I plugged into the infamous "K" harness,,As it has had 2 0f the recall fixes
DOUBLE CHECK WHAT YOU PLUGGED THE CLB INTO!!!!!!!
I really appreciate all the advice and patience you guys have given!! Regardless of the outcome tomorrow I am grateful and am hoping for the best!!
Had to go "Outside the box" though!! Several tries were unsuccessful,,even went so far as putting the K harness to get back to start for a new start for an install,,that didn't work! Finally started by connecting the original factory harness to start over, key to on,pull #25 installed CLB,,,NO GOOD!!! Pulled 25 and waited (per instructions),,,still no good!!Studied fuse diagram and found 2 other BCM fuses,,IDEA!!!! Pulled #13,BCM-11, #23 BCM-2,#25BCM&IPC ,,+ I pulled #29 (read that somewhere in the tons of stuff I read) Waited 10min+ ,,Put them all back in inserted the key turned it on,,,,Low and Behold DIC read ,,,,,DOOR AJAR!!!!!
:h urray: Went for a quick test drive and put the dash back together!!! Might post this as it Might help someone else!! Thanks for all who pitched in!! Called Bill Curlee and thanked him as well. Got my CLB For $40 shipped and beat GM!!! Going to hang the "K" harness on my shop wall as a TROPHY!!!
