2 questions about afr's
2. Price is a concern realistically how much more HP and TQ would these heads provide me? I'm really just looking to break the 400 HP to the wheels barrier. Wouldnt PRC cnc ported heads get me there on my A4 and save me roughly 1000 dollars so i could get my rims powder coated and get some tint
Looking for some honest thoughts not the old "you get what you pay for "cause that isnt all ways the case.
I'd like to see what people have gained by adding just afr 205's to a mild cam.
Thanks alot
Big money equals big power gains everywhere and an increase in drivability and the good ole fun factor across the board....
PM or call me if you need any other input/advice etc.
Cheers,
Tony
(661)257-8124 Ext. 109
I dyno'd at 370 RWHP. I like that way the car ran, but :
I changed cams to the TSP228R, added AFR heads milled .020, and 3.90 gears I dyno'd the car again on a differant dyno a couple years later and the car came in at 425 RWHP. ( be plus or minus 10 RWHP on any given dyno)
A couple differances came into play here :
1) At that time of my second dyno, my tune really sucked and had some misfiring and timing was getting pulled in the upper RPMS
2) I had changed gears from stock 3.42 to 3.90. That will show some loss in RWHP and RWTQ
The math I did was I added 10 RWHP for the change from TR224 to
TSP228R and added 40 RWHP for AFR heads baced on stock gears.
I came out with about 5 more RWHP than I thought even after I added the 3.90s
The car is dialed in pretty good now, and runs much better than on the day I dyno'd it. If I dyno's it now, Id be about 440RWHP with the not really ported FAST 90/90 added.
This is the important part. Pull up my dyno in my sig and take a look at my torque numbers on the 425 RWHP pull. My torque is 400 RWHP. I think the torque numbers on AFR heads are higher than non AFR heads. TQ is were the fun is !
You'll enjoy the car ALOT !
Of course he aleady had a cam so a big potential gain from a stocker was already accounted for.
My math of a 100 RWHP gains breaks down as follows (and this isnt "ricer math".....LOL....these gains I have witnessed numerous times on both engine and chassis dynos).
Heads....35-40 HP
Cam....40-45 HP (mild cam like our 224/228 AFR cam)
UD pulley (no brainer mod while your there)....5 HP
Ported FAST 92/90 set-up....20-25 HP
ALL of these figures are very realistic....add them up
BTW....all of them already assume a decent set of 1.75 headers....that's a must that needs to be included to reap the most gains from everything else discussed.
Call or PM me if you need some advice...
Cheers,
Tony
This post talked about
AFR 205 heads (from AFR)-----$2365 assembled, is milling it more?
Cam 224/XXX (from AFR) -----$400
gaskets (what kind?) -----------------$50
underdrive pulley (what kind?)-------$240
FAST 90/92(?)-------------------$1000, $2k if ported
Long Tubes (LG w/ cat back)----$2000
Not mentioned here, but does he (or anyone) need a new throttle body? LS2, BBK, ported? What about rocker arms, springs, push rods? What else am I missing? What vendors have good prices?
What about a clutch?-----------$2000
Edit 1:
okay just reread the original post and he was just asking about AFR head vendors...so I expounded a little...sorry to thread jack.
Edit 2:
And of course a tune, or the tuning software $500
Never ridden in Ike's car, but I have seen it run a time or two!!
Very impressive!!!
