mass air flow sensor wiring question
Old Sep 8, 2008 | 01:28 PM
hacksawjones's Avatar
hacksawjones
3rd Gear
Default mass air flow sensor wiring question
I have an aftermarket 85mm MAS sensor from SLP Performance parts.
It has three wires - black/grey; yellow, red.
I know that one wire is ground, one is + voltage and one is signal.
Would like to know which is which and is the +voltage 12V or 5V?
Thanks in advance for any help. I cannot find any information on this.
Old Sep 8, 2008 | 02:12 PM
lucky131969's Avatar
lucky131969
Since your sig is devoid of any info, I can only assume that you have a 2000 or older C5 that uses the three wire MAF. If this is the case, they are as follows:
Pin A: Yellow wire-signal
Pin B: Black/White wire-Ground
Pin C: Pink Wire- Ignition voltage
All this info is available in the engine controls section of the service manual.
Old Sep 8, 2008 | 06:02 PM
hacksawjones
3rd Gear
Thakns for the reply. That was my first post.
It is a 3 wire sensor and does have yellow, blk/wht and pink.
Actually this MAF is not going on a car. Its being used on a piece of test equiipment with a fan and I need to measure flow but did not know how to hook it up.
Ignition voltage being 12V? Is there a chance it could be 5V DC?
Thanks again.
Old Sep 8, 2008 | 06:37 PM
lucky131969
Thanks again.
Yes, the ignition voltage is 12volts(input to the MAF), the 5 volts is output from the MAF to the PCM.
Old Sep 8, 2008 | 09:24 PM
hacksawjones
3rd Gear
Thanks very much for your help with this.
To mass air flow sensor wiring question
