HELP!!!!.....ebcm/scl....HELP!!!!!
Old Sep 9, 2008 | 07:13 PM
ikester12's Avatar
ikester12
Cruising
Default HELP!!!!.....ebcm/scl....HELP!!!!!
hey everyone,
I have a problem, for a wile now ive been getting the "service traction control, ABS, and active handling" warning on the DIC. I decided not to fix it right away because $1,000 is a bit much, but the car was still drivable! A few days ago i get into the car and it say "service steering column lock" now the car will start and i can turn the steering wheel fine but when i let out the clutch the fuel shuts off. My car did go in for the recall fix back in 04. I had the vett towed to the dealer and they tell me that the steering column lock (SCL) is broke because of the broke EBCM (Electronic Brake Control Module). So here is my Question: Is the SCL a part of the EBCM or are they just trying to get an extra $1,000 out of me to fix the ebcm even though its not related?
PLEASE HELP,
Thanks in Advance
Old Sep 9, 2008 | 10:47 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by ikester12
hey everyone,
PLEASE HELP,
Thanks in Advance
Run!!!! Run Forest Gump! Run as a fast as you can!!! No....your being scammed!!!!!!!!!!!!!! Or ripped off or mis informed ,,what ever you want to call it!
I give you the answer! $$$$$$$$$$$$$$$$$$$
There NOT causing your Issue together.
BC
Old Sep 9, 2008 | 10:57 PM
byronhunter's Avatar
byronhunter
Hey ikester, better listen to Bill!
Old Sep 10, 2008 | 04:08 PM
LoneStarFRC's Avatar
LoneStarFRC
BC
Two different systems.
Change your EBCM yourself: www.absfixer.com BTW, I would recommend the extra $50 Surge Suppression upgrade they offer too.
Old Sep 10, 2008 | 04:34 PM
rws.1's Avatar
rws.1
a forum member name module repair does the fix for $99
Old Sep 10, 2008 | 04:36 PM
rws.1's Avatar
rws.1
here is th elink to module repair's store
http://myworld.ebay.com/modulerepair...MEFSX:SELLERID
To HELP!!!!.....ebcm/scl....HELP!!!!!
