HVAC electrical diagram
Old Sep 12, 2008 | 08:48 PM
sublime1996525's Avatar
sublime1996525
Default HVAC electrical diagram
I fried my HVAC and was wondering if anyone actually has a wiring diagram for the HVAC. I've checked a decent amount of posts and there are people saying they have it so if someone does can you help me out? PLEASE!!!!
Thanks,
Franklin
Old Sep 13, 2008 | 12:32 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Send me an e-mail with your e-mail address and I'll get it to you tomorrow. That way I don't have to upload it to a server.
Old Sep 13, 2008 | 12:41 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Also post what year vette and whether it's the manual or dual zone.
Old Sep 14, 2008 | 11:32 AM
sublime1996525
It's an 02 w/ dual zone climate.
Thanks,
Franklin
Old Sep 14, 2008 | 07:31 PM
sublime1996525
Anyone know what this is that is circled. It's off the circuit board that plugs into the wiring harness of the car. I think I might have fried it. Thinking maybe a voltage regulator.
Old Sep 14, 2008 | 10:33 PM
BLOWNBLUEZ06
If it is, ST microelectronics makes one. The part # for the 7994 is LD1085c. You can buy one from Digikey for 2.73. It is on catalog page# 1010. You might want to make sure that circuit board trace is intact before you start chasing a replacement part. That trace looks bad and could be open under the white plastic plug. If you have to repair it, you can just solder a wire from each end and do it on the back side of the circuit board and drill through to cross sides of the board if necessary. Put the board in front of a light to make sure it's not a multi-layered board before you drill.
Old Sep 19, 2008 | 02:29 AM
sublime1996525
I checked the trace and it is good. That's the only piece I'm worried about. Thanks a bunch
Old Sep 19, 2008 | 04:23 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
What symptoms are you experiencing with the HVAC and why do you suspect that part?
Thanx...
Old Sep 19, 2008 | 10:51 AM
sublime1996525
Right now I'm not experiencing any problems, but I did have a short which is what blackened the trace. I just noticed that the trace goes thru the part so I was wondering what it was before I hook it up and start the car for fear that something might go bad.
Old Sep 19, 2008 | 07:06 PM
sublime1996525
Ok I am having an issue. The led lights stay lit the entire time. I turned the car off, went back 30 minutes later and the lights are still lit. I think I have an idea what that component does. Anyone else have any suggestions?
Old Sep 19, 2008 | 07:27 PM
tstar's Avatar
tstar
That happened to a unit I was installing LEDs in for a friend, one of the LEDs got shorted (happened during shipping) and caused some smoke and exactly what you are experiencing.... A new power board fixed it, but we already know the culprit is on it. Can you trace back from the lighting pins coming from the display board? Third and Sixth ones in from the Black wire I believe...
Tim
Old Sep 19, 2008 | 07:50 PM
BLOWNBLUEZ06
Ok, With those schematics I sent you, unplug the controller and meter the 2 main grounds. If you're missing a ground, it could be sourcing the ground through another path which could possibly cause your problem. One is black and the other is grey and black.
Old Sep 19, 2008 | 07:51 PM
sublime1996525
What do you mean about tracing back? There was a short, fixed it, tested the led's like you are saying, 3rd and 6th from black. What else can I test?
BLOWNBLUEZ06
Also, make sure you only have 12v where you're supposed to.
Old Sep 20, 2008 | 01:19 PM
sublime1996525
Ok I'll try that. Thanks.
Old Jul 24, 2009 | 03:22 PM
mvette66's Avatar
mvette66
I have posted this on a new thread but what I am trying to find fits perfect for this thread. I did the resolder fix to bring back my display but found only the display and led's are working all the lamps are dead. I found this blown and missing a big chunk of it and trying to find the part # for it:
If someone knows the part # or has a wiring diagram I would be very thankful my email is mvette67@hotmail.com.
Thank you,
Mike
To HVAC electrical diagram
