Piston to Valve Clearance?
Old Sep 14, 2008 | 12:04 AM
JuicedVette381's Avatar
JuicedVette381
Default Piston to Valve Clearance?
Cam and head ?????
HEY PEOPLE NEW TO THE SITE. I bought a Lunati Camshaft. The Specs are
Advertised Duration (Int/Exh): 300/300
Duration @ .050 (Int/Exh): 242/242
Gross Valve Lift (Int/Exh): .595/.595
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 3500-6500
Includes: Cam Only
Part Number: 55009LUN
I Also bought LS1 heads ported and polished. these specs are:
2.02 intake and 1.60 EXHAUST
LS1 STAGE 3 PORTED HEADS
HEADS ARE PORTED. AND FLOWED @ 28" H2O
241 CASTINGS & 225 CC INTAKE PORTS
flowed on a Super Flow 600 Bench no pipe on a 202 valve.
Will i have piston to valve clearance?
