Stubborn Rotors. Please help.
Old Sep 13, 2008 | 01:52 AM
AWard's Avatar
AWard
New Member
Default Stubborn Rotors. Please help.
I have followed everyone's instructions on how to remove the rear rotors on my 50th Annie. I Used copious amounts of rust remover, I have pried and hammered every inch of the damn things. I have pulled and twisted and swore up and down at them and nothing. I have applied and released the e-brake several times already and checked the e-brake linkage at the back side of the rotors, which is currently slack(with the e-brake released) so the e-brake is not grabbing anything right now. There is no threaded hole in the rotor, so using a screw to force it off is out. There is no give, no play, from the rotors at all.
I am at my wits end. Does anyone else have any other suggestions as to how to remove these damn rotors off of my Annie? Anything would be greatly appreciated. Thanks in advance.
AWard.
Old Sep 13, 2008 | 02:00 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Damn, That sucks.
Are they in rough shape?
I dont know, keep at it, Maybe try a little heat? They'll come eventually.
Goodluck.
Old Sep 13, 2008 | 02:10 AM
lucky131969's Avatar
lucky131969
AWard.
heat is your friend
Old Sep 13, 2008 | 07:29 AM
Bill Dearborn's Avatar
Bill Dearborn
Try loosening the lug nuts just a little so the wheel wobbles a small amount and then driving in a figure 8 at about 3 mph or so. The weight of the car may be able to break it loose.
Bill
Old Sep 13, 2008 | 08:25 AM
vsocks1's Avatar
vsocks1
Bill
Old Sep 13, 2008 | 08:42 AM
liljohnny555's Avatar
liljohnny555
St. Jude Donor '08
John Deere ??
Old Sep 13, 2008 | 09:13 AM
rws.1's Avatar
rws.1
IF beating on it with a large rubber mallet didn't do it then the low speed figure 8 with loose lug nuts is the best bet....
Old Sep 13, 2008 | 10:15 AM
ALVETTE00's Avatar
ALVETTE00
I used a torch and a mini sledge hammer...came right off!
Old Sep 13, 2008 | 03:29 PM
tech2262's Avatar
tech2262
get A BFH (Big fuking Hammer)
Old Sep 13, 2008 | 09:24 PM
cdkcorvette7's Avatar
cdkcorvette7
Step 1 - Heat
Step 2 - Hammer
Step 3 - Repeat 1 and 2 until they come off
If that fails either take it to the local wrench or...http://www.youtube.com/watch?v=IvwA6...eature=related
Good Luck!
Old Sep 13, 2008 | 09:49 PM
stormrider's Avatar
stormrider
I know this is a long shot but did you make sure there are no retaining washers on the studs? If the rotor hats are rusty/dirty it would be easy to over look one of those washers.
Old Sep 14, 2008 | 12:05 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi AWard -
I have seen rotors stuck due to corrosion on the hub center - use some sandpaper or other abrasive to clean up the hub where it protrudes from the center of the rotor.
Penetrating oil - I like PBlaster, sprayed on the lug studs at the base, and then use the peen end of a ball-peen hammer to tap the areas between the lug studs.
Then, use a large dead-blow hammer to rap on the outside edge of the rotor - on the swept-area of the rotor, in a radial pattern.
Generally speaking, if the hangup is the parking brake internals, you can feel (and see) some give when pulling or tapping on the rotor.
If the problem is corrosive adhesion, you have to do the above procedure, or apply heat as suggested.
best regards -
mqqn
To Stubborn Rotors. Please help.
