Lowering- front end problem
Old Sep 14, 2008 | 12:57 PM
shihiran's Avatar
shihiran
Default Lowering- front end problem
Hey vet nation, i was trying to lower my 98 c5 but the front bolts were locked up.so what should i do now? Take the spring out or what?
Old Sep 14, 2008 | 01:22 PM
tabbruzz's Avatar
tabbruzz
Just did my 99 this morning. What procedure did you follow?
Zo Sex's Avatar
Zo Sex
what you nee to do is jack the car up with one jack and find another crappy little jack out of one of your other cars use that jack to jack up the side of the leafspring you are working on. this takes he pressure off of it and makes it easier to loosen. also add some penatrating oil!
Old Sep 14, 2008 | 03:34 PM
Justin-Sane's Avatar
Justin-Sane
i'm in the same boat, on my dad's vette the front lowering bolts are rounded off BADLY.
i've thought about cutting the bolts off, then dilling them out as a last resort.
Old Sep 14, 2008 | 04:21 PM
iced98lx's Avatar
iced98lx
soak them in anti-sieze & wd-40 and leave it over night.. don't round them off.
Old Sep 14, 2008 | 04:44 PM
vjjack04's Avatar
vjjack04
It's not difficult to remove the spring. I would remove it, put it in a vice, spray the bolt with penetrating fluid, and use a wrench (I have seen a smaller pipe wrench used for the way it leverages pressure) on the lower part of the bolt. You should be ablle to make it work.
Old Sep 14, 2008 | 04:54 PM
Midwest Vette's Avatar
Midwest Vette
I had a stubborn bolt on mine, I sprayed it with some Kroil let soak over night and it did free up.
Old Sep 14, 2008 | 09:25 PM
shihiran's Avatar
shihiran
TO LATE THEY ARE ROUND UP BEFORE WE EVEN STARTED.LOOKS LIKE I WILL HAVE TO TAKE THE SPRING OUT.THANKS EVERONE
To Lowering- front end problem
