Anyone permanently installed a CTEK?
Old Sep 15, 2008 | 05:51 AM
Choreo's Avatar
Choreo
Default Anyone permanently installed a CTEK?
Has anyone permanently installed a CTEK Battery Charger in a C5?
If so, where did you mount it, connect it, run the plug, etc.?
Old Sep 16, 2008 | 03:35 AM
coolbubba's Avatar
coolbubba
Default Dream Car Garage...
They installed one on a Ron Fellows edition C6 on an episode not too long ago. They put it in the back in one of the bins in the corner, they drilled a hole through the tub and put cord through a weathertight grommet. The end (plug) was ran along to just above the liscense plate and could be tucked up by the reverse lights when not in use. I'm sure a very similiar install could be had on the C5 as the two cars are very similiar in design and construction- especially in that area.
Old Sep 16, 2008 | 07:47 PM
Choreo's Avatar
Choreo
I saw the C6 install, but it looked like the battery was in the rear? That was why I wondered if anyone had done a front install on a C5?
Old Sep 17, 2008 | 09:11 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
kind of pointless to me. clamp it on when you need it remove it when you do not. Either way you are going to be plugging a chord to it why bother bolting it down under your hood?
To Anyone permanently installed a CTEK?
