Dtc code 1571 what is it?
Old Sep 15, 2008 | 09:01 PM
speedygc5's Avatar
speedygc5
Default Dtc code 1571 what is it?
I have a dtc code 1571 that comes out when i check my codes on the display panel of my cluster.
Does anyone know what that code means?
Any help would be greatly appreciated.
Thanks in advance.
Old Sep 15, 2008 | 09:14 PM
c5streak's Avatar
c5streak
I see by your sig you have a '97. That code will not delete on the '97s, it's always gonna be there. It's part of the TC/AH control system. Chances are it's been there a long time. There have been a few post about it lately, I'll try to find them.
EDIT: OK found it!
Are you getting any messages on the DIC regarding Traction Control or ABS?
If so, check your codes when the message appears, before you shut the car off, and see if the P1571 has an H or C after it. If your aren't getting any warnings, then it's probably been there for a while.
Here's a link that explains how the 1571 code is thrown, thanks to BlackZ06 and Bill Curlee for the good info.
http://forums.corvetteforum.com/show....php?t=2089169
Old Sep 15, 2008 | 11:37 PM
speedygc5's Avatar
speedygc5
Thanks man i appreciate your help.
I will be getting the car tuned soon, so maybe i can delete it then.
Old Sep 16, 2008 | 12:52 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
ASR Desired torque, that code lives in my pcm. I never know it's there till I check the codes. If I clear it the code will be back in no time. Mine is a 97 also. Don't worry about it..
Old Sep 18, 2008 | 08:23 PM
speedygc5's Avatar
speedygc5
Great thanks.
To Dtc code 1571 what is it?
