04- Fule pump removal
Old Sep 16, 2008 | 11:53 PM
Crockettman's Avatar
Crockettman
Default 04- Fule pump removal
I'm trying to remove my left side fuel tank.I've got the exhaust and shields off. I need to know how to disconnect the crossover fuel pipe that goes to the other tank.It looks like it twists of somehow. HELP!!! Thanks....Crockettman.
Old Sep 16, 2008 | 11:55 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Your header reads "fuel pump removal" if you're trying to remove the fuel pump, you don't need to remove the tank. Only about 9-7mm bolts.
Old Sep 17, 2008 | 01:26 PM
gorillavet's Avatar
gorillavet
He said 04...correct me if I am wrong but I thought that year it was actually in the tank.
Old Sep 17, 2008 | 07:11 PM
c5streak's Avatar
c5streak
That is correct.
The manual shows a positioning clamp, that must be released by pulling a tab and rotating the collar counterclockwise. Then the crossover tube should be pulled straight out of the tank.
Good luck!
To 04- Fule pump removal
