Creaking noise
Old Sep 18, 2008 | 01:02 PM
JROW's Avatar
JROW
Default Creaking noise
Have a creaking noise coming from the rear of my car...I'm guessing this is shocks? Any other ideas, suggestions, common problems? Anyone have any recommendations for replacement, prices, where to buy?
Thanks.
Old Sep 18, 2008 | 04:32 PM
JROW's Avatar
JROW
Car is a 99 btw...z51.
Old Sep 18, 2008 | 05:35 PM
lucky131969's Avatar
lucky131969
Thanks.
C6 Z06 shocks are a no brainer from GMPartshouse.com.....but then again, you are "guessing". Troubleshoot the problem instead of throwing parts at it.
Old Sep 19, 2008 | 07:56 AM
JROW's Avatar
JROW
Thanks, I'm hoping someone could help me troubleshoot the problem, however..........................cricket s.
Old Sep 19, 2008 | 01:48 PM
timemender's Avatar
timemender
Creaking is usually from rubber (or poly) bushings.
Sway bar isolation bushings are prone to creaking - squeaking.
Apply a lube such as ”white lithium grease” to these areas.
Parts must be disassembled to lube properly – to insure that grease is applied deep within.
In my experience spraying “silicone lube” on bushings seems to make the creaking worse.
Old Sep 19, 2008 | 03:24 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree with the bushings. I just usually replaced them when the creaking would start up as they are cheap. Once I tried the lubrication method and it sure did not work for me.. made it a lot worse, so they were probably badly worn out. I replaced them and no more problem.
Old Sep 19, 2008 | 05:14 PM
JROW's Avatar
JROW
Thanks. Sounds like some solid advice.
To Creaking noise
