Maf question
Old Sep 19, 2008 | 01:29 PM
Blow Torch's Avatar
Blow Torch
Default Maf question
Well; Due to the feedback I got here and another thread, I swapped out my "heavily ported" MAF for a stock, descreened one. Now; I haven't had any issues with the ported one, but because of feedback that the stock ones would be better for part throttle, I swapped back.
The car was dyno turned with the ported MAF, once after new heads, and again after my cam and a few more mods. The problem is, since I have swapped back, the car just won't idle. It "hunts" from 600 to 1500 rpm, and shuts off when I put it in gear. I have probably only put 50 miles on it since I swapped, and was getting no better. Since I'm leaving tonight (Friday) going to the Mountains (In the car) I swapped back, and now it idles PERFECT)
Question; Is this because the tuner somehow matched the new airflow during the tune? I have HPTuners (Still learning) but there is no time to make adjustments before I leave, so when I return, what should I do?
Old Sep 19, 2008 | 02:34 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Yes. The measured airflow and resulting output frequency is affected by the removal of the screens and porting. It's not necessarily flowing more air, but the calibration has been compromised with the MAF modifications. It would require tuning with the other MAF for it to work. Anytime you swap out your MAF, you're going to have this issue I'm sure. It will be this way unless you swap stock for stock in a PCM tuned for stock.
Old Sep 19, 2008 | 09:37 PM
LoneStarFRC's Avatar
LoneStarFRC
If the tuner did a speed-density tune, even that "little" of a change can have noticeable effects.
Old Sep 19, 2008 | 11:03 PM
VIPERBLUELX's Avatar
VIPERBLUELX
if the tuner did a speed density tune they would remove the MAF meter I'd hope
Old Sep 20, 2008 | 12:08 AM
LoneStarFRC
I've seen some that didn't though.
Old Sep 20, 2008 | 12:34 AM
FRCTony's Avatar
FRCTony
Just because you tune the VE doesn't mean you toss the MAF...
Old Sep 21, 2008 | 01:41 AM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Usually because in the '01 and up, the IAT was part of the MAF. It's easier to leave it in than rewire for the intake air temp.
You tune the VE for any/all tunes. He is referring to a speed density tune. Speed density means that you don't use readings from the MAF, so if you don't need it to hold your intake piping together, and it doesn't have the IAT integrated into it, then it is just a restriction, so yea, you can just toss it.
Old Sep 21, 2008 | 10:42 AM
FRCTony's Avatar
FRCTony
Actually, MOST tunes are MAF tunes. The VE isn't touched. Speed density tunes aren't required for headers, or a vararam...or a Centri on a stock engine.
Just because you tune in speed density mode (i.e. MAP), doesn't mean you run in speed density mode.
A MAF tune should be a LOT cheaper than a properly done speed density tune since it takes much more time.
Old Sep 21, 2008 | 05:42 PM
'VETTE PHASE
I've heard of tuning that way, but have never tried and don't know anyone that does. I guess I'm just old school and prefer to do the VE first, then do the MAF. How is the throttle response when doing just the MAF as compared to doing the VE and then MAF?
To Maf question
