Visual differences in OE springs?
Old Sep 21, 2008 | 01:57 AM
GrantB's Avatar
GrantB
Default Visual differences in OE springs?
I replaced the front spring on my '99 FRC (along with every other bit of the suspension to Z06 parts with '04 shocks and VB&P bushings), and I'm wondering if I might have gotten sold a base-model spring instead of a Z51/Z06 spring. The car exhibits significant oversteer in all states of cornering (entry, steady-state, off-throttle, track out, transitions, etc). It actually turns good lap times, considering, but the amount of oversteer is a pain to drive around.
Without a visible sticker to identify a part number on the spring, does anyone know if there are any other physical differences between the Z51/Z06 front springs and the base model?
Thanks for any help.
Old Sep 21, 2008 | 11:15 AM
LoneStarFRC's Avatar
LoneStarFRC
The front spring on the '99 FRCs is already the same spring as the Z06 cars. It's the REAR spring that must be changed to the Z06 spring (FE4). Try that.
Btw, the changeover is waaay easier too. I found a couple 6" C-clamps helped a lot during the process. Just use some wood or other durable material to protect the spring when using the C-clamps.
HTH
Old Sep 21, 2008 | 01:08 PM
GrantB's Avatar
GrantB
Thanks, but unfortunately my front spring was cracked, and I had to swap it out with another (used spring off of a 2001 Z51 car, supposedly). I've already got a Z06 rear spring (and sway bars, and '04 shocks).
Old Sep 21, 2008 | 02:40 PM
thehammer69's Avatar
thehammer69
Softening the front or stiffening the rear can cause oversteer.
Stiffening the front or softening the rear can cause understeer.
You apparently stiffened the rear while keeping the front the same...
Old Sep 21, 2008 | 03:53 PM
GrantB's Avatar
GrantB
Thanks, but I'm quite aware of that. I'm relatively sure that stock C5 Z06s are not intended to have the sort of handling imbalance my car exhibits. I'm just trying to figure out if I have the proper front spring on there, so I can move on to troubleshooting other areas...
Old Sep 22, 2008 | 02:08 AM
LoneStarFRC
It's been awhile and maybe I'm wrong but I thing there may be a problem trying to identify the springs by the sticker or label on the spring. If it's there, it wouldn't hurt to try and use that number to check, but if memory serves, any number may well be an "engineering" number and not the actual part number.
If all else fails, you may have to resort to putting a caliper on the spring and measure the thickness in two or three different places and compare to a known Z06 car. Using the "Mk1 eyeball" can sometimes be difficult.
HTH
Old Sep 30, 2008 | 04:19 AM
GrantB's Avatar
GrantB
HTH
Doh, I should have thought of that. Its hard to tell by the stamped numbers because they part #s change so often...
Both springs were the same thickness (0.74"). Onto the next troubleshooting item...
Old Sep 30, 2008 | 10:09 AM
LoneStarFRC
Just to be on the safe side, I would take measurements in at least two or three places. I'm thinking it may be possible for two springs to have the same "center section" thickness, but differ greatly in the amount of taper as you move outwards towards the ends.
On the other hand, if you can take a measurement or two on a known FE1 (base) spring and there is a big difference, then that might help as well in determining what you have.
HTH
Old Sep 30, 2008 | 02:18 PM
AU N EGL's Avatar
AU N EGL
T1 front -sway bar
Z51/Z06 front - sway bar
T1 front -top spring
Z51/Z06 front - bottom spring
Old Sep 30, 2008 | 08:15 PM
bcseitz's Avatar
bcseitz
with the caliper idea.
A base spring compared to a Z spring is very noticably different when lying side by side.
The base spring is noticeably thinner but the real difference is in the "arch" of the two front springs. The base spring has one heck of an arch to it where the Z spring is much, much flatter. Because of the big arch on a base spring they are more of a pain in the butt to install/uninstall too.
On a side note: You should see the arch on a base C4 front spring. When out of the car it almost forms a circle!
To Visual differences in OE springs?
