Head gasket thickness
Old Sep 23, 2008 | 01:06 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
bottom line here is how much hp/tq gains are we going to see w/ .015 diff between GM MLS and Cometic's??
I'll stick w/ GM parts for reliability in my dd
Old Sep 23, 2008 | 02:48 PM
billla's Avatar
billla
St. Jude Donor '14
If we're talking about the difference between something approaching .040 quench or something more like .060 quench, it's more about the HP/TQ gains since it also affects the engine's detonation sensitivity.
Old Sep 23, 2008 | 03:22 PM
SteveDoten's Avatar
SteveDoten
now maybe the gm mls units are better, more timing can be added, just maybe
Old Sep 23, 2008 | 06:09 PM
Jnape's Avatar
Jnape
I have heard this. Is it because more room for carbon to build? Or what?
Old Sep 23, 2008 | 06:15 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You can run quench as little as .030" and likely not have any issues.
And no, peak lift (alone) does not directly affect p/v clearance. You can make a .580" lift cam easily hit the pistons, and you can make an .800" lift lobe never come close.
The reason most people think it does, is because of cam lobe design...Higher lifts are a natural byproduct of longer duration in most every lobe. If you cut off the top of a steep lobe to create less total lift, you did absolutely nothing to gain p/v clearance.
Old Sep 23, 2008 | 06:20 PM
vettenuts's Avatar
vettenuts
No, it has more to do with turbulence and flow characteristics when the fuel is ignited. Good read here
Old Sep 23, 2008 | 06:23 PM
billla's Avatar
billla
St. Jude Donor '14
That's pretty tight IMHO, depending on the rod material and RPM range.
I didn't see anyone state that peak lift (alone) affected P/V, but the reverse was stated...
Old Sep 23, 2008 | 06:58 PM
Targa98's Avatar
Targa98
What i need is someone to tell me that they milled their head .060" and use a high duration cam with no probs
I believe our low valve angle is very forgiving when it comes to PTV clearance.
I am going to stay safe and try to keep .040" quench as I have stock rods and will be running high rpm.
Old Sep 23, 2008 | 07:14 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
I think you'll be hard pressed just to find anyone that milled a head that much. (and got the intake to bolt up).
chevy406's Avatar
chevy406
Originally Posted by Chevy406
Total valve lift doesn't affect piston to valve clearance....
It's certainly one (just one) of the factors in my experience. We'll agree to disagree.
I don't mean to beat a dead horse, but how is it you can agree with Y2Kvert and then claim I am stating the reverse. While Y2K did a better job explaining, he and I still are saying the same thing. Oh well, I'll let it go. Carry on with the discussion.
Old Sep 23, 2008 | 07:15 PM
billla's Avatar
billla
St. Jude Donor '14
I wouldn't hold your breath on that one
Bottom line is that you need to measure it...and check your valvetrain geometry. And, as noted anything over about .020 change in deck height is going to affect the intake.
I have to admit that I still don't completely understand what you're trying to achieve :/
Old Sep 23, 2008 | 07:19 PM
billla's Avatar
billla
St. Jude Donor '14
You made a flat statement that total valve lift doesn't affect VTP - you quote your own comment. It absolutely does, as one of the factors, which is what both I and Y2Kvert said.
Old Sep 23, 2008 | 07:20 PM
  #33
02gt350's Avatar
02gt350
pretty sure stock is .55
Old Sep 23, 2008 | 07:53 PM
  #34
vettenuts's Avatar
vettenuts
he wants to mill my heads .060"
and he sunk my valves .030" from the valve job
That may really alter flow characteristics and intake alignment.
Old Sep 23, 2008 | 09:26 PM
  #35
Targa98's Avatar
Targa98
really?? he is going to cut the intake surface also that it will bolt up normally, thought that was normal to do. The guy I am using is a close friend and was taught by casey at SAM. He specializes in LS1 and pro stock stuff so if he wants to sink the valve thats what I'm gonna let him do. He is always on the phone with casey asking for advice or opinions.
I talked to him last night and he said he knew someone that milled the head something crazy like .100" and used a 240 cam or something huge and they had no PTV probs.
If no one has done what I am doing, then would anyone like to share PTV problems they have experienced with stock/milled heads?
Old Sep 23, 2008 | 09:30 PM
  #36
billla's Avatar
billla
St. Jude Donor '14
Good luck!
<unsub>
Old Sep 23, 2008 | 09:47 PM
  #37
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
I'm not saying what you are talking about doing is impossible....I meant good luck finding someone else who's done it and can share experience.
You seem to have a pro race team with immense knowledge and experience doing your work, yet you ask here about quench and gasket thickness details, and inability to measure such details...kind of odd, if not a changing story.
I'm running 59cc big valve 5.3 heads that were milled .025" with a .040" gasket and a 240/244 111 lsa cam. That produced a negative p/v clearance value (also called interference) which flycutting cured. (I didn't sink the valves though).
!0k or so miles on the setup, not had a problem with it yet. Rev limit is set at 7200. YMMV.
To Head gasket thickness
Old Sep 24, 2008 | 07:00 PM
  #38
Targa98's Avatar
Targa98
HAHAHA, no pro race team here, just very qualified people on my side. The problem is, he is 2 hours north of me, and he is doing this for me for free so I am not expecting him to do any research for me. He has my heads, and the rest of my motor is down here with me. I am putting in the legwork for him and bringing him the numbers, ya know? Now he is telling me I will not need to cut reliefs, but people on here are... guess we will find out the hard way.
Old Sep 24, 2008 | 07:21 PM
  #39
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
I have to ask...what heads are you using that you need to mill that much?
What is your desired compression ratio?
What are your cam specs?
Sinking the valve seats in the heads is an alternative to flycutting, yeah...but to be honest, I do not know how much (depth) you can get away with there. And if not compensating by shortening the valve stems, what does that do to rocker geometry?
There's a number of things you said will be done, that most haven't done, and people certainly can't predict what kind of clearances you'll end up with with those relatively "unknown" modifications.
Not picken on ya...just sayin...
Old Sep 26, 2008 | 06:31 PM
  #40
Targa98's Avatar
Targa98
Well, he just bought me a set of 5.3 heads to be delivered on monday. He will be selling my heads on ebay. They are done up very nicely and if anyone wants them I can get flow numbers, pictures, whatever. I imagine they flow around 300cfm at .600. But anyway, to answer your questions:
They are stock LS1 heads
Trying to get 11-11.5:1 compression ratio. Preferably the highest.
We were going to take care of that by shimming the rockers .030" because that's how much he sank the valves, then measure for pushrod length. I was on his *** about making sure I could keep my correct geometry.
As you can see, this was kind of doing it "the hard way".
So since the 5.3 heads have the same ports but shallower chambers, we have decided that the same results can be accomplished without milling with 5.3 heads with my 2.000" valves.
After all that....
I want my car back dammit
