Security light not flasing!!!
Old Sep 22, 2008 | 03:19 AM
dbiddle's Avatar
dbiddle
Default Security light not flasing!!!
HI, I HAVE A 2000 C-5 COUPE. AND AFTER I GET OUT AND LOCK THE DOORS THE SECURITY LIGHT NEVER FLASHES IN MY CLUSTER..WHY WOULD THAT BE?..IT HAS NOT FLASHED IN A LONG TIME.I NEVER NEW WHY..BUT IT RUNS GREAT AND EVERY THING ELS IN THE CAR IS OK..ANY INFO ON WHY THIS MIGHT DO THIS AND HOW TO FIX IT WOULD BE SO GREAT...THANKS
Old Sep 22, 2008 | 06:56 AM
EHS's Avatar
EHS
It's not supposed to flash.
Old Sep 22, 2008 | 08:36 AM
bluvette79's Avatar
bluvette79
the red light flashes, correct
Old Sep 22, 2008 | 07:05 PM
dbiddle's Avatar
dbiddle
Default Now red light flashing that i can see in cluster??
Nope..no red light is flashing in my cluster or dash after i get out ant lock the doors..the lights blink and the inside lights come on for a bit..But thats it..no light flashes to let me no the alarm is on or even working..Need help with this..cause if i lock the doors you cant get in. so i can i tell if the alarm is working or not?..What kind of test can i do or what can i check..And feed back on this would be great guys..Thanks DB.
Old Sep 22, 2008 | 08:33 PM
mnotx's Avatar
mnotx
Theft-Deterrent System
SECURITY
With this system, the
SECURITY light will flash
as you open the door
if your ignition is off. This
light reminds you to
arm the theft-deterent
system.
Arming the System
Use one of the two following items listed here to arm
the system:
Press the lock button on the remote keyless entry
Open the door. The SECURITY light should flash.
Lock the door with the power door lock switch.
The SECURITY light will stop flashing and stay on.
Close the door. The security light should go off.
Now, if a door or the hatch trunk lid is opened without
the key or the remote keyless entry transmitter, the
alarm will go off. Your horn will sound for two minutes,
then it will go off to save battery power. And, your
vehicle won’t start.
The theft-deterrent system won’t arm if you lock the
driver’s door with a key, the manual door lock, or if you
use the power door lock after the doors are closed.
If your passenger stays in the vehicle when you leave
with the keys, have the passenger lock the vehicle after
the doors are closed. This way the alarm won’t arm,
and your passenger won’t set it off.
Old Sep 22, 2008 | 10:11 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Get in the car and close the door, then lock it with your fob only. Try opening the door and see if the alarm sounds.
To Security light not flasing!!!
