New product from Hardbar.net
They sell for $595 and we have 3 in stock.
and they have the following features:Fast Performance - maximum height reached in 6 pumps.
Low profile - extremely low starting height, (3.5 inches) designed especially for racing cars.
Durable - The highest grade die cast aluminum combined with the patent hydraulic system while meeting all of ZINKO's high standards make this jack as close to trouble free as you can get.
Universal - 3,000 lb capacity, combined with a notched lift cup that has a removable rubber insert for fits on all types of cars.
No stop bracket required. Handle automatically stops at 12 o'clock vertical position. This insures no damage to the car body.
Heavy duty full service real caster wheel for easy movement.
Superior quality, durability & function make this jack the leader, all others will be trying to catch.
Gary Hoffman
hardbar.net LLC
603-682-8073
[Modified by ghoffman, 11:34 AM 1/7/2002]
Thanks Gary!
The Evo2 will fit as well as the Pro2000 and of course, the Evo.
I do make and sell the rails, but not the seats themselves, do a search for Sparco and find your best deal. They are totally bolt in, and normally the lead time is a month or so (I am making a bunch in the next 2 weeks or so). They are $200 in non powdercoated and $235 powdercoated and the lead time is sometimes more for the powdercoated due to minimums at the coater's shop. We now have 3 mills (including a new 3 axis CNC). The passenger side with active handling is $250 due to the "doghouse" needed to clear the yaw rate sensor on the floor.
[Modified by ghoffman, 8:30 PM 1/7/2002]
