No Trans temp readout ?
Old Sep 23, 2008 | 10:56 PM
TWOBUELLS's Avatar
TWOBUELLS
Default No Trans temp readout ?
Not getting a readout for the trans temp when pushing gauge button.
I get all the other readings , oil temp , oil pressure , ect. ect. just not the trans temp.
Any idea's ?
joe
Old Sep 23, 2008 | 11:03 PM
lucky131969's Avatar
lucky131969
Any idea's ?
joe
Wow....I've got the exact same problem with my six speed....
Old Sep 23, 2008 | 11:09 PM
Robls6's Avatar
Robls6
It's not part of the DIC readouts. It only warns you of an abnormally high temperature situation.
Old Sep 23, 2008 | 11:13 PM
TWOBUELLS's Avatar
TWOBUELLS
Old Sep 24, 2008 | 12:05 AM
lucky131969
Can you explain how it warns of an "abnormally high trans temp" condition?
Old Sep 24, 2008 | 12:12 AM
lucky131969
Any idea's ?
joe
I'm sorry TWOBELLS, just making a little funny. The reason you cannot read the trans temp, is because there is no trans temp sensor in an manual vette(unless it's an export/Z06). If you had an auto in your vette, you would be able to monitor the transmission temperature.
Old Sep 24, 2008 | 09:05 AM
Robls6's Avatar
Robls6
There is a temperature sensor in the trans. It just isn't an option on the DIC to display the temperature unless it is abnormally high.
Old Sep 24, 2008 | 10:57 AM
lucky131969
What your saying is true for your car (Z06), but there is no temp sensor in a non export MN6. The auto trans has a temp warning, as well as a tranmission temperture reading in the DIC.
Old Sep 24, 2008 | 12:16 PM
Robls6's Avatar
Robls6
I stand corrected. Actually... I'm sitting
Old Sep 24, 2008 | 05:40 PM
David426's Avatar
David426
the z06 has no trans temp tradout ot tire pressure sensors
Old Sep 24, 2008 | 06:28 PM
MUKAK's Avatar
MUKAK
maybe u should lay down...
lucky131969 is correct
Old Sep 24, 2008 | 07:38 PM
Robls6's Avatar
Robls6
Thats why I said I stand corrected...
Old Sep 24, 2008 | 07:40 PM
MUKAK's Avatar
MUKAK
ok, u standing again
Old Sep 24, 2008 | 09:01 PM
Robls6's Avatar
Robls6
HA! Actually now I am laying down.
To No Trans temp readout ?
