DIC question
Old Sep 25, 2008 | 05:06 PM
Sinister-one's Avatar
Sinister-one
Default DIC question
Just ran a quick errand. Whe i started the car the DIC read..... "Charge System Fault".
What the heck is that ?!?!?!
Old Sep 25, 2008 | 07:16 PM
Big_George_S's Avatar
Big_George_S
Do a search on the message you will find a number of post on this topic as I have the same problem. Recommendations are to check both the battery terminals and the battery cable down to the starter make sure contacts are clean and tight. I've not done either and still get this message evey so often it goes away and the car runs fine and always starts. Amp gauge starts around 14 then falls back to a range of 12.5 -- 13.5.
Old Sep 25, 2008 | 11:32 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The only time I ever saw that message on my '99 was just before the positive battery post fell off and it started dumping acid. Check your battery cables, alternator wire, battery cable at the starter and between the battery and fuse box, there is a ground on the frame.
Old Sep 26, 2008 | 08:41 AM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
Its either a bad connection or your battery is failing. Time to get a Diehard.
Old Sep 26, 2008 | 09:51 AM
Sinister-one
The battery terminals both look good. Connections are good and tight. Looks like I'll be crawling under the car this weekend to check the starter connection.
Old Sep 26, 2008 | 01:30 PM
djengr's Avatar
djengr
I too have an intermediate flashing of the "charge system Fault" I have checked grounds, battery connections etc. It comes up every 2-6 months. And it only comes up once and it clears, then it won't come up again for, 2-6 months.
Last time was about July, from recollection.
Good Luck and post if you find anything.
Old Sep 26, 2008 | 03:09 PM
Sinister-one
That's EXACTLY what happens with me.
To DIC question
