Tranny trouble!!
Old Jan 7, 2002 | 10:23 PM
SR1654's Avatar
SR1654
Default Tranny trouble!!
I just got word from my repair shop that my transmission is gonna cost 2,500.00 to repair since the third drum is shot! :cry :cry And if that was not enough, my right rear runcrap goes flat at the shop! :( At least I had the new Nittos here ready to go and had the runcraps replaced today. Now I get to wait a week for the tranny to be rebuilt! :sad: When things go wrong, they REALLY go wrong. Pray for me and my C5..we NEED it!!!
Old Jan 7, 2002 | 11:27 PM
TLewis4095's Avatar
TLewis4095
Default Re: Tranny trouble!! (SR1654)
How many miles on it? Did you race regularly? Any symptons before hand? Huh? Huh? 34k here racing on a regular basis without a whimper or a slip...Hope yours was a rare instance. :eek:
Old Jan 8, 2002 | 09:51 AM
levrac68's Avatar
levrac68
Been there and done that, unfortunatly. I feel for you. :(
Old Jan 8, 2002 | 09:54 AM
oceanaire's Avatar
oceanaire
Sorry to hear about your tranny. That sucks. But you can turn that negative to a positive by geting a hold of Yank or FLP and putting in a "Reinforced" tranny for not that much more. :yesnod: Good luck. I hope you get her on the road soon. Eric :smash:
Old Jan 8, 2002 | 02:36 PM
Jim Kramer's Avatar
Jim Kramer
Default Re: Tranny trouble!! (oceanaire)
:yesnod: I would look at a YANK tranny. I think they run $3500 or so...
Old Jan 8, 2002 | 02:44 PM
oceanaire's Avatar
oceanaire
Default Re: Tranny trouble!! (VetteMan2k1)
No, not that expensive. Check it out: http://www.converter.cc/ click on HP Trannies. Good luck! Eric
Old Jan 8, 2002 | 02:48 PM
RWhite's Avatar
RWhite
This brings up a question I would like to ask. I have a new C5 A4 and will be modifying it over the next few years (bolt-ons first and then stall, cam and heads). I am well aware of tranny problems related to higher than stock HP mods and the resulting fixes that one must go through. Believe me, I have gone through a number of AOD's and a few C4's over on Ford's I have had, but am not familiar with GM tranny's. Some questions (remember, my C5 is 3 days old to me!):
1. Does the C5 have a radiator type tranny cooler or the inefficient type that just runs the fluid through a tube in the coolant radiator?
2. Do the typical shift kit mods help and are recommended?
3. I have noticed many going to various torque converter upgrades (which I know are probably needed for ultimate A4 performance). Along with the converter upgrade, are there any other mods that need to be made (computer mods, etc.)?
Thanks!
Old Jan 8, 2002 | 03:47 PM
oceanaire's Avatar
oceanaire
Default Re: Tranny trouble!! (RWhite)
1. I believe it is cooled by running through the radiator, as a seperate tranny cooler was recommended for me.
2. I have a Transgo shift kit which works fantastically. Will it wear out the tranny faster? Probably!
3. I had new gears installed at the same time as the TC and computer programming was necessary.
I'm no expert. I hope this helps. There are a lot of "REAL" experts on this Forum. Maybe they will chime in and answer more correctly.
[Modified by oceanaire, 2:48 PM 1/8/2002]
Old Jan 8, 2002 | 10:28 PM
geekracer's Avatar
geekracer
Check that out. You might want to Yank that tranny :smash:
To Tranny trouble!!
