back up light????
Old Sep 26, 2008 | 02:22 PM
ClockworkC5's Avatar
ClockworkC5
Default back up light????
one of my back up lights was out so i went to replace it. the side that worked had 2 filaments. both light when i press the unlock on the fob. the other side, that wasnt working, was a single filament. went to auto zone, got the light they said to use. was a double filament. now the side that wasnt working works but only one filament lights up. it is much dimmer then the one that has always worked. any ideas?
Old Sep 26, 2008 | 02:45 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The backup lamps only have one filament. Look in your owners manual for the correct lamp #. It probably a 2057
Old Sep 26, 2008 | 02:50 PM
DeeGee's Avatar
DeeGee
Its only the stop/tail lights and DRLs that are dual filament.
with Dave its a 2057
Old Sep 26, 2008 | 04:05 PM
ClockworkC5
i picked up sylvania bulbs part # 2057 and the have 2 filaments. now one side lights up both filaments and the other only one.
Old Sep 26, 2008 | 06:50 PM
dgrant3830's Avatar
dgrant3830
Wow, you are right.. the owner's manual calls for a 2057 which you are correct that its a double filament.. but it shouldn't be. Do me a favor and look inside the bulb socket itself and see if there are two contacts in there or just one please... You sure got me!!!!
Here's whats in the manual for a '99
Replacement Bulbs
High-Beam Headlamp . . . . . . . . . . . . . . . . . . . . 9005
Low-Beam Headlamp . . . . . . . . . . . . . . . . . . . . 9006
Front Parking/Turn Signal . . . . . . . . . . . . . 3157 NAK
Back-Up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2057
Front Sidemarker . . . . . . . . . . . . . . . . . . . . . . . . . 194
Rear Sidemarker . . . . . . . . . . . . . . . . . . . . . . . . . 194
Rear Stop/Tail and Turn Signal . . . . . . . . . . . . . 3057
For any bulb replacements or procedures not listed here,
please consult your dealer.
Old Sep 26, 2008 | 07:12 PM
dgrant3830's Avatar
dgrant3830
Please enter your profile and especially the year/model of your car. This has got me bugged now!
I'm wondering now if there are two different backup light modes.. daytime and nighttime therefore using the two different filaments?
Old Sep 26, 2008 | 07:16 PM
ClockworkC5
im with you. the bulb has two contacts on the bottom of the bulb. the socket that receives the bulb only contacts one. im confused. on my drivers side with one contact, both filaments light up. on the other with one contact, only one filament lights up. the double filament makes sense to me. one when you put it in reverse, and the other when you put it in reverse with the lights on. however the socket only has one contact, and one lights both, and the other lights one. ive got a 2000 coupe
Old Sep 26, 2008 | 07:24 PM
dgrant3830's Avatar
dgrant3830
Do you have your owner's manual and if so, what does it say for the lamp?
One contact in the socket means it should normally be looking for a single contact bulb. The fact that a dual filament bulb is working is only because the the single contact socket is shorting across both lamp contacts
I looked up your car and its supposedly a 2057...doesn't make sense. Do yourself a favor and send a PM to Bill Curlee. He's the electrical expert here
I'm wondering if someone before you replaced the sockets for some reason?
Old Sep 26, 2008 | 08:13 PM
65GGvert's Avatar
65GGvert
I'm not quite sure why you would need two filaments. The back up lamps come on and off independently of the tail lamps, so it wouldn't matter if the lights were on. The backup lamps are in the lenses by the license plate, have yours been moved to the tail lamp sockets perhaps?
Old Sep 27, 2008 | 10:17 AM
ClockworkC5
both sockets are the same and look original. im guessing that one light was replaced. there were 2 different lights bulbs when i took them out. the one that worked had 2 filaments and the one that didnt had one.
Old Sep 27, 2008 | 03:48 PM
bestvettever's Avatar
bestvettever
Default Back Up Light
Hi, the 2057 is the specified bulb. Replace both bulbs and they should be the same brightness. Different brands can have different perceived brightness, and also bulbs grow dimmer with time and use. The fact that they have 2 filaments even though the socket calls for only one is probably due to the universality of parts these days. You could find a bulb with only one filament that would fit, and that is probably what the other bulb was doing in there.
Good Luck
Old Sep 28, 2008 | 01:45 PM
ClockworkC5
both lights are new. one side both filaments light on, the other only one filament lights.
Old Sep 28, 2008 | 06:23 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Maybe one side lights with the approach lights when you hit the fob. The other could just be wired to the reverse switch. Somebody should be able to tell with a wiring diagram/schematic.
Old Sep 28, 2008 | 06:51 PM
bestvettever
Default Back up lamps
Hi, what you are saying is making me think that the side that lights both filaments has the socket contact in a place that is hitting both filament contacts on the bulb, while the other side's contact is maybe a hair off from hitting both filaments.The side that is not lighting both filaments, take the bulb and drop a bit of solder on the contacts to bridge them and you will have both sides lighting both filaments.
Good Luck
Old Sep 28, 2008 | 10:06 PM
dgrant3830's Avatar
dgrant3830
That's the only thing that makes sense is that they are using a single socket contact to hit both bulb contacts. Sure don't understand why they didn't use a single contact bulb with the right wattage though...
Old Sep 28, 2008 | 11:39 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
It's been a while since I looked but it used to be that dual filament bulbs had staggered pins so they would only install one way. That was needed since the brake light function / turn signal filament was brighter that the tail light filament.
On single filament bulbs the pins were set even and it could be installed two ways: IE 180 degrees off.
Does the backup light socket have a single contact but the grooves are cut for staggered pins on the bulb?
Old Sep 29, 2008 | 12:48 AM
lionelhutz's Avatar
lionelhutz
Well, is the contact in the socket small about the size of one of the pins on the bulb or is it large enough to touch both pins at the same time? Or, is the contact in the socket off centre so that it's only going to hit one contact on the bulb.
The contact position and the slots for the pins not being even as posted above both existing are the 2 things that would point to GM picking the dual filament bulb for that application.
I'm thinking the dual filament bulb has a brighter brake/stop filament than most common single filament bulbs so it was a better choice. Maybe it's not supposed to light both filaments but the contact in your one socket got moved. Or, it is supposed to light both and the bad one is dirty or off somehow. It's also possible the pins on the bulb aren't even enough for the socket contact to touch both at the same time.
So, describe the socket or take some good pics.
Peter
To back up light????
Old Sep 29, 2008 | 12:31 PM
ClockworkC5
took some pix but dont know how to put them up. the insert picture button asks for a url?
each socket looks identical, the contact is off center.
Old Sep 29, 2008 | 05:38 PM
Blue 92's Avatar
Blue 92
The pictures have to be hosted on a web site. You then enter the URL to the image.
Old Sep 29, 2008 | 06:02 PM
lionelhutz's Avatar
lionelhutz
About the easiest site to use is tinypic.com. Once you upload the pic you get the links you can copy to post it here. Use the IMG Code for Forums & Message Boards.
If the contact is off center then it should only be hitting one of the contacts in the bulb and only lighting one filament.
Peter
