clutch install
Old Sep 28, 2008 | 12:06 AM
LSX4LIFE's Avatar
LSX4LIFE
Default clutch install
looking for help on clutch install, 2000 cpe i was told it is a hard job.
Is there more than one way of doing the install, does any body have pic,
or step by step that will give me an idea of the job thanks for the help
curt.
Old Sep 28, 2008 | 12:37 AM
intoc6s's Avatar
intoc6s
It depends on your resources.(lift, etc). I think that most talented greasemonkeys could do it. Check out ls1howto.com . The second time is always a breeze! Good Luck!
Old Sep 28, 2008 | 12:44 AM
Quik Z06's Avatar
0Quik Z06
Former Vendor
http://www.cajundude.com/differential.htm
That has some great pix and helped me alot. Its for the diff, but you need to drop the tranny and diff to replace the clutch. I would say if you are mechanically inclined you can do it, if not I wouldn't try it. I have done it a few times and could probably swap a clutch in 4 hrs or so beginning to end. It does help that my friend has a lift and lot's of tools.
Old Sep 28, 2008 | 01:14 AM
Targa98's Avatar
Targa98
I did mine without a lift. Not hard at all, just takes some time your first time. No, there is not a bunch of ways to do it. Drop the drivetrain and pull the torque tube from the bellhousing, DON'T try to pull the motor. Trust me, I wondered the same thing, and now after having done it, pulling the drivetrain is much easier. the entire rear clip drops with four nuts. Then lower the drivetrain on a jack, NOT TOO LOW! Unbolt the torque tube and voila! there's the clutch! It will prove useful to have an extra set of hands to help guide and balance the heavy stuff.
Old Sep 28, 2008 | 01:32 AM
Quik Z06's Avatar
0Quik Z06
Former Vendor
I'll also add, get yourself a cheap tranny jack, it helps alot. I think I paid $40 for one.
Old Sep 28, 2008 | 04:39 PM
Targa98's Avatar
Targa98
Old Sep 28, 2008 | 04:46 PM
fst85vtt's Avatar
fst85vtt
Its not bad at all in the process now just put a ls7 clutch in mine
Old Sep 28, 2008 | 04:53 PM
vettenuts's Avatar
vettenuts
Here's some info on how I did my re-alignment.
Link
Old Sep 28, 2008 | 06:08 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Cheap tranny jacks at harbor freight. My only tip is don't jack the car too high cause then your jacks won't reach. Oh and of course add a remote bleeder.
Old Sep 28, 2008 | 06:40 PM
Targa98's Avatar
Targa98
What the hell is everyone talking about remote bleeders for? Totally unnecessary. Serves no purpose. My new RAM slave was a self bleeder. Don't know about the others but they should be too.
Old Sep 28, 2008 | 07:29 PM
vettenuts's Avatar
vettenuts
Remote bleeder makes bleeding the clutch much easier, especially after its all together and you want to do a fluid flush. Mine is located right at the power brake booster so I can fill and hold the bleeder into a bottle at the same time. My better half does the pedal duty
Old Sep 29, 2008 | 10:11 AM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
Where are you located? Maybe we can point you in the direction of a shop if you wanna go that route.
Old Sep 29, 2008 | 12:21 PM
randy814u's Avatar
randy814u
Old Sep 30, 2008 | 01:02 AM
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
Never seen a self bleeder. I added a remote bleeder because it's almost impossible to reach the factory bleeder screw. It made the original bleed process simple. And as already posted future fluid changes will be a snap. So they do serve a purpose and aren't totally unnecessary. $50. is money well spent on this item.
Old Sep 30, 2008 | 11:47 PM
LSX4LIFE's Avatar
LSX4LIFE
Just want to say thanks to everyone for your help. Its going to be a winter project, h/c intake are first. Thanks again curtis
Old Oct 1, 2008 | 05:43 AM
vettenuts's Avatar
vettenuts
Which intake? I found I had to remove the FAST for the clutch.
Old Oct 1, 2008 | 05:50 AM
Quik Z06's Avatar
0Quik Z06
Former Vendor
^ You had to remove your intake manifold to replace your clutch?
To clutch install
Old Oct 1, 2008 | 10:00 AM
FASST LN's Avatar
FASST LN
I thought the same thing until I read the write-up regarding the DTE brace install (very good write-up, but still over my head ).
Apparently when lowering the rear, it torques the entire engine backwards and forces the intake and rear of the engine to make contact with the firewall. Too much of this can crush your firewall.
Apparently our torque tubes have a picture on them warning of this.
And that is one of many reasons why I will never install my own clutch
Old Oct 1, 2008 | 12:06 PM
vettenuts's Avatar
vettenuts
The FAST was getting precariously close and it has been ported, so the investment in it is big. Wasn't worth the risk, it comes off in 10 minutes, so I just pulled it for the clutch swap.
Old Oct 1, 2008 | 01:27 PM
zeevette's Avatar
zeevette
Man, I'm glad you mentioned this...thanks.
