HID lights
Old Sep 29, 2008 | 10:53 AM
oneshot's Avatar
oneshot
Default HID lights
Got a question, I replaced my low and high beams with HIDs from Nissangtrpower over the weekend. I had to reverse the stock wires to the ballast to get them to fire up. But when I first turn on the lights the lights are dim, then brighten up. I kinda expected that. But when I am on the road and I switch from low to highs it is way to long to get to full light. If I switch from highs to lows, it is not too bad. They glow pretty bright right away.
Any ideas. I replaced the fuses with 15amp as well. Is this comman!
Old Sep 29, 2008 | 03:38 PM
Corvette Don's Avatar
Corvette Don
Yes this is common, this is why most leave the stock HIGHS in there and just use the HID lows as it does take 5-10 seconds for them to become fully lit/warm up.
Old Sep 29, 2008 | 10:10 PM
lionelhutz's Avatar
lionelhutz
You could wire up some relays to keep the lows on when you switch to highs.
Peter
Old Sep 29, 2008 | 10:32 PM
oneshot's Avatar
oneshot
thanks guys, I guess I will switch back to my normal high beams.
Old Sep 29, 2008 | 11:11 PM
bassman12350's Avatar
bassman12350
You'll want to wire in relays to leave the low beam (HIDs) on with the highs. It drastically shortens the life of and is very hard on the HID capsule to be cycled on and off with Hi/Lo beam selection.
Old Sep 29, 2008 | 11:13 PM
rws.1's Avatar
rws.1
I'm learning on this one...
Old Sep 30, 2008 | 01:13 AM
bassman12350
Yup......Gotta agree, this is probably the most controversial subject one could discuss in the annals of automotive equipment...........
To HID lights
