Problem putting my A4 in drive
Old Sep 29, 2008 | 11:41 PM
mechanix19's Avatar
mechanix19
Default Problem putting my A4 in drive
I have a 98 A4 that is giving me trouble putting in gear. I'll get in the car start it up and push the button on the shifter to go into Drive but it doesn't engage. I have to push the button a couple times and push the shifter back and forth to get it to move. This problem just started and I couldn't find anything searching past threads. ANyone encounter this problem or know what can be the cause? Thanks in advance.
Old Sep 30, 2008 | 07:40 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Pushing the button on top of the shifter has nothing to do with engaging any gear in the transmission, all it does is lower a pin from a detent to allow the shift lever to move.
Are you saying that you put it in "D" and the engine revs without the car moving?
If so, put it in Drive rev the engine 5 or 6 times and see if the car starts to roll and if it does then you may be low on fluid, if it fails to roll at all until you work the shifter back and forth from "N" to "3" and finally to "D" then you may either have a bad shift cable, it could have slipped out of adjustment or worst case scenario, you could have internal transmission problems.
Old Sep 30, 2008 | 08:58 AM
mechanix19's Avatar
mechanix19
No, I'm saying I simply can't move the shifter to put it in Drive.
Old Sep 30, 2008 | 01:25 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
OK, there is an electric solenoid on the shifter, remove the shift plate and you'll see it. With the shift plate removed, start the car and step on the brake pedal, then watch that solenoid to see if it deenergizes, if not then it most likely needs to be replaced or you can do like some people have done and just disconnect the pushrod from it and be done.
Old Sep 30, 2008 | 03:54 PM
Wildcats's Avatar
Wildcats
Default automatic not going into gear
I have a similar problem. When in park, I sometimes have a difficult time shifting into neutral to get to drive. I have to use abnormal pressure for it to move. I have not checked it out yet but plan to this winter.
To Problem putting my A4 in drive
