We knew you could do it! Any one that is about to lower their car should start w/ the front first. Get it at the desired height, then do the rear which compared to the front is a walk in the park. Good job.
Ok my car has f45 by the way. I went for spirited drive and then remeasured. I got one full inch out of the front and didnt get any from the rear. The front was just way too low although it looked awesome, the gap was perfect. I raised the front a few turns and then on the rear I turned the bolts til there were no threads showing and went for another drive. I measured again and the front raised 1/4 inch which made it 3/4 inch lower than stock and the rear droppped 1/4 inch from stock. Im sure the rear will settle some more though and then I will make more adjustments if need be before I get it alligned which is needed because it doesnt drive perfectly straight right now.
I just did mine two weekends ago after 6+ years of the monster gap. I had over 3.5 inches of gap between the fender and the tire. Now it's much nicer. I use the water bottle test. If you can get a water bottle between the tire and fender it's too much.
Mine's a daily driver, so lower on the stock bolts is good for me. I got about 3/4 drop all around. Back may need to come down a little more at some point.
For all the guru's -- not meaning to highjack but probably helpful to OP too -- what happens when you lower the rear more than you lower the front? It changes the angle of the car. Are there any negative effects????
Most will probably say you want the front end slightly lower than the rear for the down force it provides...better handling and less air under the car for stability.
