Rear Mounted Transmission Cooler
Old Oct 1, 2008 | 04:18 AM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Default Rear Mounted Transmission Cooler
Has anyone installed and run a trans fluid cooler mounted in the back of the car, like behind the rear facia? I know I'd need a fan, but do you guys forsee any other problems?
Old Oct 1, 2008 | 09:34 AM
Fast one's Avatar
Fast one
I tried that location without a fan and the temps went up not down so it was relocated in front of the car where the air is cool. The cooler is in series after the radiator cooler and the temps are low now, usually 170- 200 degrees F.
Old Oct 1, 2008 | 10:06 AM
AU N EGL's Avatar
AU N EGL
not a problem
Lots of guys use the ZO6 rear brake ducts in the rocker panels. They put the trans cooler on one side and a diff cooler on the other side.
This way fresh moving air goes though the ducts and small radiator.
DRM ( forum Vendor ) sells this set up.
Old Oct 1, 2008 | 10:13 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
I have seen several successful setups with the cooler mounted in that location, but you will definitely need a cooler with a fan.
Old Oct 1, 2008 | 04:31 PM
Mister Peebody
Thanks Fellas - Anyone have pictures of rear setups and/or cooler recommendations?
I'm not up for installing Z06 ducts but I can see it being effective.
Old Oct 1, 2008 | 04:42 PM
exploder's Avatar
exploder
I installed mine in the rear bumper area with a fan wired to pull air all of time and also cut vents in the rear black paneling and it still got too hot. I would not run it in the bumper. My cooler was too big to fit in the fender well so I have no experience with that. Just put it up front below the headlight and fab a few brackets. It works twice as well up there and I haven't seen temps go over 160 yet with normal driving.
Old Oct 1, 2008 | 06:00 PM
C5SCCA's Avatar
C5SCCA
C6-R runs a cooler in the back. I actually have a picture of it, but I am not smart enough to post pictures.
Old Oct 2, 2008 | 12:52 AM
Mister Peebody
Thanks a million for all of your experiences and opinions. I will post my results, once I have some to report.
Old Mar 23, 2009 | 01:26 PM
Greg MFn Z's Avatar
Greg MFn Z
St Jude Donor '14
Results?????
To Rear Mounted Transmission Cooler
