Euro Tail Light Gremlin......
Old Oct 5, 2008 | 05:16 PM
Cliff99C5hardtop's Avatar
Cliff99C5hardtop
Default Euro Tail Light Gremlin......
I put the back bumper back on my car early today and pulled the car out of the garage to just make sure everything works correctly. Well I am glad I did, I noticed that when I hit my left directional only one of the yellow bulbs works and that's the one closest to the passenger side, the one all the way on the driver's side did not work. I switched the bulbs around and there is nothing wrong with the bulb. Also, the driver's side marker light does not work, bulb is fine there too. What to do????
Old Oct 6, 2008 | 11:28 AM
Cliff99C5hardtop
One other note, I had the euro tail lights in my car for a couple years......this is a recent issue. I think I may have a loose wire or the harness has a short in it.
Old Oct 6, 2008 | 11:56 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Check the harness connector just behind the passenger rear wheel. This connector has a tendency to come loose. I was having intermittent problems until I safety wired the connectors together.
Old Oct 6, 2008 | 01:44 PM
Cliff99C5hardtop
Thanks!! I will check that out later.
Old Oct 7, 2008 | 02:10 PM
Cliff99C5hardtop
Ok.... I found out that one of the bulbs was bad, the filament was loose.....not your typical broken filament. Now, I am having an issue with the drivers side marker light not coming on at all.
I am not sure and maybe someone can remind me, do the marker lights on the rear fenders, do those only blink when the directionals come on or are they on the whole time your lights are on???
Old Oct 7, 2008 | 04:02 PM
DeeGee's Avatar
DeeGee
They're on all the time when the lights are on
Its a 194 bulb but you need to go in through the tail light to change it.
To Euro Tail Light Gremlin......
