I have a banging / squeak in my vette. It sounds pretty loud. I put it up on rack and everything is tight, ball joints, shocks, etc. How loud can I expect the bushings to be?
If it isnt the bushings in the sway bar does anyone have any other ideas?
I looked at all suspension, and the pin that attaches sub frame.. all looks good... lost..
I had a very loud banging, creaking noise when I took my coupe out this spring for the first time. It was so bad I turned around immediately and put it back on the lift. Turns out the grease in the sway bar bushings had almost liquified and was ineffective, causing the sway bar to stick badly. Some new grease and it was good as new in 15 minutes.
You didn't say way year you have, but if you have a pre-2002 then you might want to look at your sway bar end links. The black hard rubber ones on the early years will fail and have a noticeable clunking sound when that happens. If that's the case, replace all four with the forged steel ones that came on the later C5s.
I had a lot of rattling on mine and kept checking and not seeing anything. Well when I changed over to some new pfadt bushings the noises all went away. Now I just get a slight squeeky noise. But I will take that over the cheap japanese car noise I was getting.
I forgot to post, you looked at everything but did you put a wrench on anything? If not, try actually tightening everything you can get to. There are a lot of bolts that will make noise if they are just 1/2 turn or less loose. Not even really loose per say but rather just not tight enough so they can slip.
