Difinitive answer on alignment after lowering
Old Jan 9, 2002 | 01:19 PM
CP's Avatar
CP
Default Difinitive answer on alignment after lowering
Yes, you absolutely should do it.
In 18,000 miles, my front tires wore down to the metal belts in the inside edge.
Old Jan 9, 2002 | 01:32 PM
GR8-LIFE's Avatar
GR8-LIFE
Default Re: Difinitive answer on alignment after lowering (CP)
ooops!!! Thanks for the suggestion.
Old Jan 9, 2002 | 01:57 PM
99 Torch Coupe's Avatar
99 Torch Coupe
Mine did the same thing before I lowered it :confused:
Old Jan 9, 2002 | 01:58 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Difinitive answer on alignment after lowering (99 Torch Coupe)
I'm getting mine aligned tomorrow morning at COH.
Old Jan 9, 2002 | 02:03 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: Difinitive answer on alignment after lowering (rschiltz)
Got Milk? There is no way you shouldn't get one!
Got Alignment.......if not then go get one dude!
Old Jan 9, 2002 | 02:10 PM
jetskifast's Avatar
jetskifast
Ran 17,000 miles without alignment after lowering on my stock wheels. Tires showed no signs of abnormal wear.
As long as you do not cut bushings. Lowering with GM adjusting bolts should keep your car in algnment specs.
[Modified by jetskifast, 2:59 PM 1/9/2002]
Old Jan 9, 2002 | 02:12 PM
WGreen's Avatar
WGreen
Cruise-In I Veteran
10,000 miles later my fronts were toast. Nothing a new set of fronts and an alignment could not fix.
Old Jan 9, 2002 | 08:07 PM
BillY2KFRC's Avatar
BillY2KFRC
Default Re: Difinitive answer on alignment after lowering (jetskifast)
Didn't have that experiance here. My alignment was WAY off after lowering, and I didn't cut any bushings, just lowered on the bolts. You sound like you got lucky with the tire wear, but I bet if you put your car on an alignment machine and you'll be at least a little bit off spec. Having the right alignment really affects your cars handling. For $50, it might be worth getting your's checked out at the dealer.
Old Jan 9, 2002 | 08:46 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: Difinitive answer on alignment after lowering (BillY2KFRC)
Yep, I did not cut any bushings and the inside edges of my front tires are severely worn after 7k. The back seem fine(and I did use lowering bolts there).
Old Jan 9, 2002 | 08:53 PM
Paradigm's Avatar
Paradigm
Default Re: Difinitive answer on alignment after lowering (C5-VERT)
It's a must do.
Old Jan 9, 2002 | 09:13 PM
RichieRich's Avatar
RichieRich
I lowered a while back and never had the car aligned. Seemed fine. I HAD to get it aligned recently cause of a little mishap running over something on the freeway. The guy showed me the factory specs for the car and how mine compared on the computer printout. The rear definitely needed re-alignment. (front did from the impact). Only a small percentage off on the alignment sheet translates to a lot once you get out to the wheel. Best to get it done. The computer's numbers don't lie. After lowering, the car is out of the spec'd range by a noticeable amount.
Old Jan 9, 2002 | 11:07 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I have 42,000 miles on my original GY runflats .. it is lowered and I never had it aligned I lowered it when I had less than 2000 miles on the car..I should get 45,000 miles out of these run craps.. and I ve never had a problem with them
Old Jan 10, 2002 | 10:15 AM
6Speeder's Avatar
6Speeder
7,000 miles on my tires after lowering (did not cut the bushings), no alignment, and no abnormal wear. In an earlier post someone said the alignment value that changes when lowering was camber, and slight negative camber is added with lowering. For a coupe or Vert, that is a good thing for handling, it brings your alignment closer to Z06 specs. For those who checked, WHAT was changed ? How much? :confused:
Old Jan 10, 2002 | 11:26 AM
JWSchmidt3's Avatar
JWSchmidt3
Sorry Paul, there's just no validity to this. It's a good idea to get an alignment every year, but there is still no proof lowering requires an alignment. Many people slam their cars, don't do an alignment, and drive forever without an alignment and no tire wear. JMO. :cheers:
Old Jan 10, 2002 | 07:50 PM
CP's Avatar
CP
Default Re: Difinitive answer on alignment after lowering (JWSchmidt3)
Well, maybe, but the way I feel now is that not getting the car re-aligned has cost me some amount of $$ due to premature tire replacement. The new tires may or may not last this long. I only have one data point from which to extrapolate. :yesnod:
Old Jan 10, 2002 | 08:04 PM
Ram Air Tony's Avatar
Ram Air Tony
i must be one of the lucky ones as well....my 99 hardtop had 18,000 miles when i traded it and 15,000 of them were lowered, tires looked like new
Z06 has nearly 10,000 on it lowered every mile (minus the 4 that were on it when I trailered it home) and has no abnormal wear (to my knowledge) now
guess I will go take a CLOSE look at the fronts
thanks
Old Jan 10, 2002 | 09:06 PM
Scott97's Avatar
Scott97
Default Re: Difinitive answer on alignment after lowering (Ram Air Tony)
My first 8K after lowering was fine.
I checked again at 14K and my fronts were toast. :eek:
[Modified by Scott97, 7:15 PM 1/10/2002]
To Difinitive answer on alignment after lowering
Old Jan 10, 2002 | 09:08 PM
davidmax's Avatar
davidmax
Depending on tread wear #'s you tires in correct alignment can last 7k,17kor30k.Driving style plays into it but i can tell you a good handling wet/dry tire like a pilot sport has a tread wear # of 200 the KD's I believe are the same.Any good handlind rubber works great but add a competition alignment with added negative camber and a bit extra toe in so they dont wear in 5-7k and the car will hold the road like its on rails.
Your tires will wear faster but you can still get 15-20K VS the 30+ you would get with stock specs.My LPE C5R forally a stage2 650 with a 125 lbs. of extra Turbo and plumbing weight handles far superior to my stock 01' Z06 which aint no slouch.Remember the more negative camber the better the handling and the faster the tire wear.Its a trade off you tires wind up costing 20-50% more but if you can afford it its a trade off thats well worth it,and lets face it at stock specs the car aint no slouch to begin with,outhandles 98%+ of all exotics on the road stock.Good Luck.David S. XTREME Motorsports.
(480)517-4969 feel free to call for all your needs or just info and Tech. Data.
Old Jan 10, 2002 | 09:16 PM
TeamZ06's Avatar
TeamZ06
For the umpteenth time:
significantly changing the ride height will result in significant toe setting changes
most people don't realize that an incorrect toe setting impacts tire wear more than camber. Even if you dispute my comments, an alignment is cheap insurance compared to the price of a new set of premium tires. Why be stubborn about it?
JWSchmidt3: you can doubt my word, but if it's proof you want just put the car on the rack before and after lowering. I can even tell you in advance which way the toe will change.
TeamZ06 :cool:
[Modified by TeamZ06, 7:21 PM 1/10/2002]
[Modified by TeamZ06, 7:25 PM 1/10/2002]
Old Jan 10, 2002 | 10:21 PM
JWSchmidt3's Avatar
JWSchmidt3
Default Re: Difinitive answer on alignment after lowering (TeamZ06)
TeamZ06 :cool:
Team Z06, first off, why did you specifically point me out?? :rolleyes: 2nd of all, I did put the car on the rack before and after, and no change. So "for the umpteenth time", there is no proof that lowering has an effect on the alignment of a car, at least not any of the many cars the same group of guys have been lowering around Houston. Just because "YOUR" application resulted in a difference, doesn't mean everyone elses will. If you can provide proof, instead of a "strong" opinion, please do. BTW, I see many more people posting above who have NOT needed an alignment, than those that have. :cheers:
