Re: Fastest C5 Lists (2001 Red Coupe Bandit)
98coupe Modified Vortex with 2- 4" intake tubes though Z06 screens,ported TB,LS6 Intake manifold,Carrol supercharger,CNC ported heads,TTS headers,Random Technology high flow cats,Borla XR-1 exaust,B&M Ripper,Vinci HiPo Line lock,42# fuel injectors,Lingenfelter upgraded fuel pump,Kenne Bell Boost-a-pump,custom Comp cam for SC,Custom Ross forged blower pistons,prolite forged rods,treated key wayed crankshaft,Manley racing pushrods 1pc cromoly,ARE oil pump,f45 with z51 bars,racing heim jointed links,poly bushings,lowered 1 inch,BFG G-force kds,Complete custom paint job,373 gears,Mcloed duel disk,Ajustable AP master,Z06 slave,custom scatter shield,Be cool double wide radiator with lower stat and auto high speed fans setup,DRM Rollbar,Eradispeed CrossDrilled/slotted Rotors,Hawk pads,Steel braided lines and Zo6 calipers up front with AO engineering 4 piston rear brake calipers Z06 Rear brake ducts,Custom Catch can,PCV check valve,Vortech aftercooler with custom tubing,Custom Dyno tune by Steve Cole SAE Corrected RWHP 548.7 RWT 465.4
wow guess I have some catch up work to do nice setup ***Drool***
I should have 1/4 times in 4 weeks with my 418ci motor, if the list is still going.
for now with current setup only mods is intake and exh.
Randy Coles 99 vert Ls1, 1.93- 60' , 12.81 @ 109 , 6sp , run flat , weight 3430 est. with driver.
