Do these runcraps ever need replacing???
Old Jan 9, 2002 | 04:32 PM
BRU's Avatar
BRU
Default Do these runcraps ever need replacing???
I know they do, but I have ~ 12K miles on them already with very little wear. I'm going with a better performing tire when they do finally bite it - just can't justify the ~ $1,000+ for tires/installation until then. What have been your experiences?
[Modified by BRU, 2:34 PM 1/9/2002]
Old Jan 9, 2002 | 04:33 PM
Tom/99's Avatar
Tom/99
Default Re: Do these runcraps ever need replacing??? (BRU)
I have 11,200 on mine, they don't show any wear as of yet. :chevy
Old Jan 9, 2002 | 04:34 PM
vstella's Avatar
vstella
Think Nitto's...$800.00 inc.tax installed.Best bang for the buck out there!:D
Old Jan 9, 2002 | 05:24 PM
TTRotary's Avatar
TTRotary
Default Re: Do these runcraps ever need replacing??? (vstella)
Heh, you guys must be doing something wrong...I burned mine down (all four of 'em) to the tread wear bars inside 7K miles. Guess it was all that canyon carving plus a couple of track events :D :D
FYI, the BFG KD SSS are a huge improvement.
Old Jan 9, 2002 | 05:40 PM
GR8-LIFE's Avatar
GR8-LIFE
Run Flats are shrewd and manipulative creatures. They have the uncanny ability in fooling fool some owners into thinking they are a good tire by not wearing. They become more convincing when you get a nail - like i did the first month after I bought my car. But where are they when you truly need them, like when you go around corners? Spin Cycle, thats wear!!! Don't fall for it!!!I'm getting rid of them within the next 30 days. I'm hoping I can find a sucker ... I mean buyer ... for them.
Old Jan 9, 2002 | 06:02 PM
RajunCajun2001's Avatar
RajunCajun2001
I have nearly 8K on mine and no signs of wear yet. I've got another set sitting in the garage for when these burn off. I figured they'd only last about 10-12K like my Camaro tires, but these run flats will probably last well into 20K+ miles. I know most are anti-run flats, but they are worth their weight in gold if you ever get a flat in the middle of no where as I did. :smash:
Old Jan 9, 2002 | 06:29 PM
TTRotary's Avatar
TTRotary
Default Re: Do these runcraps ever need replacing??? (Ha-Ha)
They're actually not bad, but you must remember to push them WAAAY past the squealing pig noises. They actually have some stick once they dig in. But they will wear like a normal tire at that point. Mine sure did ;)
Where these tires are really poor is in sidewall construction, resulting in lack of compliance. They are way too stiff, which shows up in a choppy ride, and causes the skipping. This problem evaporates with the BFG KD runflats, as well as the Firestone RFPs. Also, those tires do not require special mounting equipment as do the EMTs. Newer and better technology.
Old Jan 9, 2002 | 06:52 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Do these runcraps ever need replacing??? (TTRotary)
My runcraps made it to 25k and started gettin real squirrely in the rain....so I got the Firestones and so far am really happy 1000 bucks for everything out the door
Old Jan 9, 2002 | 06:53 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Mine were toast at 14K.
Old Jan 9, 2002 | 07:02 PM
Tracy's Avatar
Tracy
Default Re: Do these runcraps ever need replacing??? (2000^C5)
The 'craps do last a long time, no doubt, unless you abuse 'em plenty. ;) They are definitley a 'compromise' tire. My biggest beef is that in cold weather they are as slippery as a hockey puck....scares me sometimes!! They'll break loose anytime!
Old Jan 9, 2002 | 07:21 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Do these runcraps ever need replacing??? (tracy)
I will usually run tires down to 0/32'nds but I can't seem to wear the rocks down. I've got nearly 22k on them (minus the track miles where I use track tires) and they just won't die.
They are very scary in the cooler weather, like tracy said they break loose at will. Since I just emptied (again) my mod fund on LT headers, X pipe, power duct, and Cross Bar I'll be waiting until spring to get some new rubber.
I've got 2 sets of track tires...they may have more grip in the rain than the run rocks!
Old Jan 9, 2002 | 07:28 PM
Snowman's Avatar
Snowman
CI 1-2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '03-'04-'05-'06-'07-'08-'09
Default Re: Do these runcraps ever need replacing??? (Gary2KC5)
You don't have to justify spending for the tires. Order your new rubber from Tirerack.com or wherever you are going to get it then just go out to a parking lot, do a personal burnout contest (take pics) and then have the new rubber mounted. There is no rule you have to wear out those puppies first! :D
Snowman
Old Jan 9, 2002 | 08:01 PM
MDL-01C5's Avatar
MDL-01C5
Exact same length here :yesnod:
Old Jan 9, 2002 | 08:11 PM
BillY2KFRC's Avatar
BillY2KFRC
Nope, things damn things are indestructable! :D After 28,000 miles, my fronts still look brand new, and the rears are just now looking like they may need replacing soon. And that's after HEAVY drag racing, and a driving school at Watkins Glen. Plus, I drive the car pretty hard on the street. Keep the car aligned and these things are good for well over 30k miles with easy driving. I'm ripping them off in a couple months and going with the Nittos, can't wait! :D
Old Jan 9, 2002 | 08:59 PM
TorchedTexan's Avatar
TorchedTexan
Default Re: Do these runcraps ever need replacing??? (Snowman)
Snowman
Mine are bald! Burnout videos coming soon!!! Ha ha ha
My rears are dead at 13k miles.... You think its my driving style?!?!? :hat : :yesnod:
Old Jan 9, 2002 | 09:10 PM
geekracer's Avatar
geekracer
The rears on my car lasted until ~20k miles, the fronts need replacig now at 23.5k miles. I'll probably replace them with run flats again.
Old Jan 9, 2002 | 09:56 PM
ace's Avatar
ace
then just go out to a parking lot, do a personal burnout contest (take pics) and then have the new rubber mounted. Snowman
You read my mind!! :D
To Do these runcraps ever need replacing???
Old Jan 9, 2002 | 10:01 PM
TorchedTexan
Default Re: Do these runcraps ever need replacing??? (ace)
Mine too! Coming soon...
Old Jan 9, 2002 | 10:10 PM
Closer_2001's Avatar
Closer_2001
Measure em, if you've got more than 6-7/32 tread remaining you should be able to sell them for at least $100/each.
Put that toward new tires and you are all set!
Old Jan 9, 2002 | 10:44 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Do these runcraps ever need replacing??? (Closer_2001)
I say pull them off the C5, sell them, and use the proceeds to help pay for better tires.
