Turned car off yesterday and smelled something burning under hood.Everything went dead,no lights and no power. Battery was hot ,so i removed it and took it to get checked ,they said it was bad battery so i bought another .Put new one in and still nothing, no lights and no power.Any ideas what this could be?It was sparking while hooking up the terminals but still no lights or power and now it doesn't even spark while touching terminals.Thanks guys in advance
Start with the basics, I just had the same thing happen on my daughters Mazda, check all the wires that you can see something is shorting out, check all fuses and relays, check all wireing harnesses to make sure they are not lose, not sure were the starter is on the vette, but I have a feeling its in a bad place or I would tell you to check that I have a feeling it could be something like that----
Did you check to see if the original battery that you took out was leaking? I did not see any details about your car so I figured I would ask. Leaking Delco batteries was a common problem and when it leaks it can leak onto the PCM and harnesses....If its not that I did have the same problem with my chevy blazer and it turned out to be a bad battery cable....Good luck
Thanks for the replies. Battery was not leaking but was very hot when i removed the terminals.Guess i have to start tracing wires just very hard to even get under car.
Fuses protect just about everything but not the main battery wire to the starter. Also check the wiring from the alternator to the engine fuse box or wherever it goes....somehow back to the battery.
Couldn't find any bare wires . Checked starter and cleaned everything i could get at. While trying to hook battery back up the terminals were arching like crazy ,like it was welding them fast couldn't hook them up. Any ideas what would cause the battery to arch that much?
Yeah, a dead short or near to it.. which is why you previously smelled something burning. Disconnect the alternator and make sure its wire is not touching anything and try the battery again. If no massive arcs, then you've found it. Next, do the same thing at the starter. Basically you are disconnecting the major circuits one at a time trying to isolate the huge current draw. Were you having any trouble with the starter prior to this? Could be the starter solenoid is still engaged... but that would cause the engine to try to turn over. The solenoid might have a short to ground as well, but that happening is pretty far-fetched. If you find the source of the burned smell, it will tell you what happened.
Pull all the fuses cept whats basically needed to crank the starter. Then start putting them in one at a time and restarting and see what happens with each fuse you put back in. Eventually you will come to the fuse hopefully that controls where the short is. Might be something simple and quick to find this way or a long haul of trial and error. This is basically the same way to track a current draw pulling fuses and watching the ohm meter.
Battery terminals will spark when hooking leads back up so thats not a significant problem.
Theres a B+ terminal on each fuse box. The one under the hood is the main one and can be used to isolate both fuse boxes. Remove the nut and two terminals and then connect the battery terminal. then ONE fuse block terminal at a time. That will basically cut the electrical system in half.
