I'm trying to decide between the Vortex and the Blackwing intake.
I like that you don't need to cut the shroud with the Blackwing, and that they now have a cover you can add later for cold air if you want.
But both together are more $$ than the Vortex.
So, if I plan to cut the shroud eventually, I might as well do it now with the Vortex.
A couple of questions:
'Why' is the air on one side of the shroud colder than the other, and 'how much' colder is it?
Have any of these companies put thermometers on each side of the shroud and driven around to see what the difference actually is?
How many degrees would be considered significant?
If it's only a few degrees, I'll probably just go with the Blackwing, but if there's a major difference, it might be worth it to cut the shroud.
Re: How cold is the cold air (intake question)? (FarmerBob2001)
With the vehicle in motion, the temerature differential if often 15-25F in stock form. With the blackwing cover, it is often 0-3F.
VERY roughly, you get about 1% more HP for every 10 Degrees of temperature reduction. The gain is not huge, but it should not be ignored if you are seeking gains agressively at all.
More exactly, the SAE HP correction calculation is:
OK. So, a cold air intake will give a few % more HP assuming a 20 degree difference. I assume the more modified your engine, the more HP you gain (the % applies regardless of the baseline?).
So, does anyone know 'why' the air under the shroud would be 20 degrees cooler? I mean, unless the air above the shroud is coming through the radiator or from the exhaust manifolds, what would make it hotter than the air under the shroud? Moving air isn't cooler because it's moving.
The reason outside air would be colder is because the inside air is from inside the engine comparment. The engine obviously creats heat and the air around it is hotter. Another advantage to cold air intakes is the ram air effect you get from them. I decided on the Blackwing for 4 reasons. 1) I didn't want to cut anything 2) I didn't like the risk, even if it is small, of hydrolock 3) I don't like the way the Vortex looks and I didn't want to spend that much for a Haltech 4) the hp differences are small :cheers:
So, the air under the shroud is coming from outside the car, and the air above the shroud is coming from the engine bay.
Cool. That answers my question. Thanks.
I haven't had time to crawl around the engine bay/under the car to try and figure that out.
Now I just need to make up my mind on which intake to get..
Yes, moving air isn't cooler, but it convects heater better. Lick the back of your hand and breathe on it with your mouth wide open. Then breathe on it with your lips pursed. Your breathe is the same temperature, but the faster moving air is a better heat transport, and cools better.
[QUOT
How many degrees would be considered significant?Thanks.[/QUOTE]
A while ago, I saw a test report by an individual, on this forum, who actually measured the temperatures under a C5 hood relative to outside air temps. His test showed a difference at rest, but hardly any difference once the car was moving. I'll try to find the link and post it. It was interesting.
Also, I don't believe there is any real "ram air" affect by any of the aftermarket intake systems. Don't forget, that engine is sucking pretty hard when it's accelerating. Kewlbrz compares this to racing down a hallway with a vacuum cleaner hose trying for a "ram air" effect while the vacuum is running. It's not going to happen.
I'm a standard Blackwing fan, personally. No shroud cutting, no exposing the filter to crap coming up off the road, including water, and a very real performance increase from the best flowing filter on the market...IMHO.
Ed
I use an autotap to check the air temperature that the engine sees. I have a cold air intake and for what it's worth I have seen a difference between 10-15 degrees between standing still and driving, particularly during hot days. I haven't measured the engine compartment air temp where the stock air cleaner is however.
I believe you are correct that "Ram Air" is a fallacy. I’ve done calculations of density changes in air at different velocities of automobile travel, and there is no noticeable increase in density until you start to get over 200 mph.
I think ram air is a marketing tool.
Similar to the throttle body bypass mod.
Common sense makes you think it will do something.
Calculations can show that you are wasting your time, and may even be taking a risk in the north of freezing the throttle open on a cold day.
As for the cold air question. Everyone knows more air = more horsepower.
I know nothing about the SAE hp calculations, but Charles Law tells us based on temperature alone that a 10°F temperature decrease will provide a 2% increase in mass air flow, or air density.
