LS7 Lifters
Old Oct 13, 2008 | 07:36 PM
legman's Avatar
legman
Default LS7 Lifters
I'm replacing my LS1 lifters with new LS7's and would like to know if the pre-loads are the same ??
Am also going with Yella Terra 6645's ....
Old Oct 13, 2008 | 07:45 PM
fst85vtt's Avatar
fst85vtt
I believe that the ls1 /ls2 ls7 are all one in the same actual part
Old Oct 13, 2008 | 08:21 PM
legman's Avatar
legman
I'm doing a h/c/i swap that requires 7.4 push rods for stock spec'd heads, which I have. Going with the YT's, I figured I might as well upgrade the lifters too. I know I'll have to check roller swipe pattern on the valve and shim as needed per YT....
Thanks....
Old Oct 13, 2008 | 09:00 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
LS7 lifters are now the "stock replacements" for all LS1/2/6/7 applications. Preload of .080-.100" is good.
No heads/cam package in existence "requires" a specific length pushrod, as there's just way too many variables involved, and shimming your YT's will most certainly and dramatically change the correct PR length needed.
Worry about the pushrods last...assemble heads/cam, dial in the rockers, then measure for proper PR length, and buy the exact length you need.
To LS7 Lifters
