Wiring Issue
Old Oct 13, 2008 | 11:27 PM
ChuckL's Avatar
ChuckL
Default Wiring Issue
After throwing a few parts at my '99 myself to try and solve ABS/TCS codes (C1276, C1285, C1288), a mechanic has determined that three wires have "pulled out" of the EBCM connector. Unfortunately, all three are light blue with no tracers. He is not interested in trying to trace them. What is the best (or only) method of trying to resolve this?
Thanks,
Chuck
Old Oct 14, 2008 | 09:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Chuck
I have to hold my head in shame. Cant believe that your post isnt even commented on yet!
So, heres what I recommend:
All three blue wires go somewhere. I will need to get to my home computer to pull up my service manuals to further advise you where the wires go. Im in Guam so you will receive the info at some really weird hour of the night!
Once you know where all the blue wires go, disconnect the connectors at those locations and using an ohm meter read one wire in the EBTCM connector and touch the other blue wires in each of the other connectors. When you read ZERO ohms, mark that wire as to where it goes.
The schematic for the EBTCM will tell me what wire goes to what pin with reference to the component that it goes to.
Send me your e-mail address and I will send you the schematic.
BC
Old Oct 14, 2008 | 10:28 PM
byronhunter's Avatar
byronhunter
Default Lt Blue wires
EBCM has a total of 5 Lt Blue wires.
Pin 6--Stop Lamp Supply Voltage
Pin 11--Left Front Wheel Speed Sensor Signal
Pin 18--Steering Wheel Position Signal B
Pin 21--ABS/TCS Class 2 Serial Data
Pin 28--Steering Position Sensor Signal
Maybe this will help you get started untill Bill can get back to you, HE is the man.
(This is from '02 Service Manual) HTH
Old Oct 14, 2008 | 11:09 PM
lucky131969's Avatar
lucky131969
That is not correct for a 99.
For a 99, there are a possible 7 Lt Blue wires as follows:
Pin 4 - SWPS B
Pin 9 - Stoplamp switch input
Pin 10 - Class 2 Serial Data
Pin 17 - SWPS Pulse
Pin 19 - Brake pressure differential switch Input (if equipped with JL4, if not the wire is white)
Pin 23 - SWPS Signal
Pin 31 - LF Wheel Sensor (low)
Old Oct 14, 2008 | 11:23 PM
ChuckL's Avatar
ChuckL
Pin 4 - SWPS B
Pin 17 - SWPS Pulse
Thanks guys. I found another mechanic today that may be willing to give it a shot. He is very good with C4's. He is going to do some research and let me know. I will be sending him this info as well. I am also sending Bill my e-mail address as he requested.
Chuck
Old Oct 14, 2008 | 11:30 PM
lucky131969
Chuck
Here are the wiring diagrams you will need to identify the wires:
http://www.flickr.com/photos/1545929...48677/sizes/l/
http://www.flickr.com/photos/1545929...48549/sizes/l/
http://www.flickr.com/photos/1545929...48431/sizes/l/
http://www.flickr.com/photos/1545929...06984/sizes/l/
http://www.flickr.com/photos/1545929...75655/sizes/l/
Old Oct 14, 2008 | 11:36 PM
ChuckL's Avatar
ChuckL
Thank you very much. I'm only a couple hundred miles from you in Macomb.
Chuck
Old Oct 14, 2008 | 11:40 PM
lucky131969
Chuck
Check my post again Chuck, I added one more wiring diagram.
Old Oct 14, 2008 | 11:57 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Lucky beat me to the punch, but I'll go ahead and post the schematics too. Everything you should need is in red.
Old Oct 15, 2008 | 12:55 AM
lucky131969
No such thing as too much correct information
Old Oct 15, 2008 | 02:50 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Dude,,,your HOOKED UP with some great info. Just do an end to end on one wire at a time and you will be able to figure it out.
Thanks guys. My slow *** connection in Guam would have made sending the documents time consuming.
MAKE SURE that you tape and secure the EBTCM wiring harness so this iss will not happen again. If you need any more assistance, all you need to do is ask.
BC
Old Oct 15, 2008 | 07:30 AM
ChuckL's Avatar
ChuckL
BC
Thanks to all for the info. Hopefully we can get this resolved.
Chuck
Old Oct 15, 2008 | 10:56 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Let us know how it all turns out!!
BC
Old Oct 15, 2008 | 11:25 PM
ChuckL's Avatar
ChuckL
BC
I certainly will.
Thanks,
Chuck
To Wiring Issue
