C1243 DC current measurements
I used a fairly large wire to keep it from heating and used a spade lug to plug into pin 8.
I used the 10 amp setting on my VOM as it was the highest scale I had I also used the leads from the amp meter as a switch to apply the voltage to the motor.
Results: The initial meter reading was greater than 10 amps and the voltage from the battery charger dropped to under 10 volts. The motor ran but was indeed slow.
I continued to run it in short bursts and eventually the current came down to 5 amps and the voltage stayed at 12+ volts.
Here is a video of the final run. You can hear the motor run. It will take
55 seconds to down load with high speed.
Observations: I am a retired IBMer and based on my experience with analog and digital circuits I think what happens when C1243 is posted: the computer has sensed that the current going to the motor is higher than a predetermined setting and assumes the motor is stuck. A DC motor will draw high current when the armature is not turning and the result is the voltage drops. I think for this type of repair it is probably better to use a battery charger rather than your battery as you want to start with a lower inital current until the armature starts turning at speed. This will save the internal circuit in the BTMV (they are called land patterns) and keeps from heating the wire. If you monitor the curernt and it drops to 5 to 6 amps ( you can read this on the battery charger) then you are done.
If you want more information send me a PM.
I also have a Simpson 260, and I have a PSM-4 {That was the predecessor to the Simpson}.
I also still use them every once in a while.I wont go into the Vacuum Tube voltmeter that I have that still works.
man, an AN/PSM-4...I have not seen one of those since I was in tech school at Chanute AFB! Good memories!
So far , so good.
BIG ISSUE - my 2000 has the ABS unit in the front, and it is REALLY hard to get to. I'm gonna research around and see if there is any way to tie into the motor relay line, and then just fire the motor occasionally when required. I'll start a new thread and see if anyone knows a trick. Here in Texas, we don't get much rain, and I try to not drive in it, so opportunities for "field testing" without ripping the tires off are pretty slim.
DG
(hint, remove the alternator, and maybe the radiator hose).
First, check the resistance of the ground wire to the frame (it sticks right out of the left side of the module. Mine was pretty grubby, but it still read 0.1 Ohms.
If that is okay, then proceed to remove the electronic (right side) of the ABS unit. 4 torx screws, and a sneaky 5th one (it's the post under the rubber shock absorber in the middle bottom).
After the electronic module half is off, find socket # 8 on the hydraulic module, they are numbered, it's the first one in the 2nd group of sockets, bigger than the others.
You want to get 12 V to that #8 socket. Just look at the spade pin in the electronic unit that plugs into socket #8, and find/make a spade wiring connector that is about the same size. Then just hook a 3-ft wire up, with a 10-15 amp fuse to be safe.
As stated earlier, I used a battery charger with an amp meter, hooked the gnd to the negative battery post on the car, and struck the positive against the wire I fabricated.
The motor will run, probably slow, or it might blow the fuse if it's really slow. just keep contacting it for a couple seconds at a time until it loosens up a bit. Then make a few 10 second passes. It should speed up and run free. I probably did about 10 10-second runs with a cooldown between each, and she was really running nice.
Pretty simple really, just hard to get it apart.
cheers,
DG
