FYI - Headlight Gear Source
Old Oct 15, 2008 | 03:06 PM
lionelhutz's Avatar
lionelhutz
Default FYI - Headlight Gear Source
Hello;
I found that you can get a replacement headlight gear as a "HELP!" item as p/n 42400. This is a gear manufactured or supplied by Dorman Products. You should be able to find it at an automotive parts retailer near you for about $15.
Peter
Old Oct 15, 2008 | 04:32 PM
DeeGee's Avatar
DeeGee
Is that a nylon gear or a brass gear?
Old Oct 15, 2008 | 06:42 PM
lionelhutz's Avatar
lionelhutz
Nylon like the original.
Peter
Old Oct 15, 2008 | 08:00 PM
stormrider's Avatar
stormrider
If you plan to keep your Vette for a long time spend the extra bucks and get brass ones so you won't have to replace the gears ever again.
Old Oct 29, 2008 | 10:50 AM
2SlowinTO's Avatar
2SlowinTO
Originally Posted by lionelhutz
Hello;
Peter
Did you put it in yet?? How long does the nylon last?
I have to do mine, and it looks like a pain in the A$$, and looks like it will take a couple of hours to do....(and its cold now....)
I think I'd rather put the brass one in, so I don't have to do it again.
ANy place in Ontario or Canada we can buy them? (that will save on duties etc...)
Old Oct 29, 2008 | 12:56 PM
LoneStarFRC's Avatar
LoneStarFRC
With 151K+ miles, my original factory nylon gears are still in mine and working fine. Guess all that hard work and clean livin' is paying off.
FWIW, I did buy a brass replacement just to have on hand. Hey you never know, right? I also lube all the linkage points about once a year too. Maybe that helps in the longveity department.
To FYI - Headlight Gear Source
