Just ordered Fast 92...MAF question
Old Oct 15, 2008 | 06:11 PM
dixonk's Avatar
dixonk
St. Jude Donor '09
Default Just ordered Fast 92...MAF question
I just ordered a FAST 92/90 combo and was wondering if the stock MAF will be fine or will it rob me of power? Something just doesn't sit right with having a 90mm opening at the throttle body but only a 78 or 80 whatever it is opening at the inlet....but then again I am no engineer.
Old Oct 15, 2008 | 07:27 PM
zeevette's Avatar
zeevette
From what I've read in tech articles, the MAF (85) on the Z is not a big impediment. Of course, looking at your extensive mods, maybe a SD tune would be in order, in which you eliminate the MAF, I believe. NICE CAR, BTW.
Old Oct 15, 2008 | 10:48 PM
dixonk's Avatar
dixonk
St. Jude Donor '09
I have been debating on SD for awhile. It was SD tuned before when I had a F1C on it and this is my first time playing around with a MAF with serious power.
Old Oct 16, 2008 | 03:58 PM
k-mart's Avatar
k-mart
I see that you're in KCMO as well. Where do you get work done on your car? I do as much as I can myself but a clutch and gears just isn't in the cards right now.
As for the MAF, I just put a Ported FAST 90/90 setup on my '98 that came with a 78mm MAF stock. I swapped it out for an 85mm MAF from a newer model. No dyno results, so I can't say if it helped for sure, but it feels a bit stronger. If you really want to be sure you're not choking the motor, you can pick up a 100mm MAF from Texas Speed.
Old Oct 17, 2008 | 04:16 AM
dixonk's Avatar
dixonk
St. Jude Donor '09
Actually I am overseas in Kuwait right now. Getting my car ready to ship back home. I will be back in KC in January. Not sure where to go there either. I have been told to go to MC Racing but not sure if they are good or not.
When you did the 85mm MAF was the connector the same?
Old Oct 17, 2008 | 07:47 AM
dixonk's Avatar
dixonk
St. Jude Donor '09
Well I think I found my solution...lol...it's called search I didn't know that all 2002 and up models came with 85mm MAFs. I thought it was smaller than that. I guess I can live with a 5mm difference. I read somewhere that the MAF outflows the TB anyway. Not sure how true that is because I am by no means an engineer.
Old Oct 17, 2008 | 11:20 AM
black98c5's Avatar
black98c5
Kevin, Are you still staying with F/I? I hope so, you have one bad a$$ ride!!!
Old Oct 17, 2008 | 04:16 PM
dixonk's Avatar
dixonk
St. Jude Donor '09
No it's back to N/A. Got tired of all the problems with the F1C setup it was just overkill in everyway. I'm having more fun with the N/A power now. Shooting for a solid 480 to 500 now.
Old Oct 17, 2008 | 04:24 PM
black98c5's Avatar
black98c5
A N/A 408 is still a monster. 500rwhp should be a breeze with the right H/C package. Good luck and keep us posted.
Old Oct 17, 2008 | 04:30 PM
dixonk's Avatar
dixonk
St. Jude Donor '09
Well I am struggling because of my cam choice. I have the GT11 in it now which is pretty small but hoping my compression helps me out some. I have another cam sitting aside which is pretty big but I really like the way the GT11 drives and feels so I am going to make it work. Heads are good to go though
To Just ordered Fast 92...MAF question
