Procharge or Not
Old Oct 16, 2008 | 09:10 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Default Procharge or Not
Just picked up a procharger D1-sc stage II. If I want to put it on I have to swap my cam for another cam, sell my head 11:5.1, and buy a set of heads and send them out for a lower compression 9:7.1, then put the Procharger on. What do you think? Any info will help.
Old Oct 16, 2008 | 09:34 PM
02gt350's Avatar
02gt350
what do you do with the car?
BTW, i have stock LS1 heads if you need some lower comp heads. they are uber cheap and im 2 hours south of you
Old Oct 16, 2008 | 09:36 PM
4DRUSH's Avatar
4DRUSH
Boost it
Old Oct 16, 2008 | 09:37 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
1/4 mile. drive on a nice day.That is it.
Old Oct 17, 2008 | 10:26 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
What heads/cam do you have now. What's your current compression ratio?
I don't believe you'll be able to get to a 9.7:1 CR without changing the connecting rods. Stock heads with stock gaskets (about a thick as you can go) get you 10.5:1.
The other question I have to ask is why?
There are plenty of people running superchargers with bigger cams (as long as the LSA isn't too small) and there are plenty who run with stock or even higher CR.
Unless you're going to forge the bottom end, 550-600rwhp is about the limit. You can get that on minimal boost. Alky injection would probably be a must for the higher compression ratios.
Old Oct 17, 2008 | 10:45 AM
black98c5's Avatar
black98c5
You can always pick up some 317 heads to lower your compresion. What are your cam specs? I'm going to be running my G5X3 112 lsa cam with my F1C build this winter (N/A cams not working well with F/I is a myth). I would also run Meth for safety i.e. cooler IAT's and prevents detonation...
You should stop in the F/I section.....Lots of guys over there running 550rwhp-600rwhp+ with stock bottom-ends. A lot of it has to do with the tune. Don't get too greedy and it should last. The beauty of the D1SC is that if later you want to go forged, 700rwhp+ is a breeze.
Congrats on your purchase!
Old Oct 17, 2008 | 11:16 AM
Drewstein's Avatar
Drewstein
Procharge it!
Old Oct 17, 2008 | 03:11 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
429 rwhp SI007 cam 228/222 .588, .581 lift 114.5 LSA , RGR stage 1 LS6/243's, Ported 11:5.1, Mille .020, 918springs, ( STOCK VALVES ), Comp 918's, Comp Pushrods, Taylor wires, ARP head bolts, SLP Crank Pulley , Port Matched LS6 intake, Raptor XXL and air bridge, SW LT's with no cats, B&B prt catback, Delphi 38# inj. , 3.90 gear (stock rear), Hawk Pads, 35% Tint, lowered (stock bolts), C6 z06 shifter,SpdKlz DIC and door panel lights (blue LED), tinted rear lights, Loyde mats, Corvette Parts partition
Old Oct 17, 2008 | 04:02 PM
black98c5's Avatar
black98c5
The cam you have will be fine in a boosted application. There is a guy I know that is making over 600rwhp with a MTI X1 cam and it's only slightly bigger ( 230/227 .591/.571 ) then your 007 cam from speed inc. Swap the heads to drop the compression and add an Alky kit for safety and you should be good to go. Oh, and you probably won't want that SLP underdrive pulley on there as well.
Old Oct 17, 2008 | 05:02 PM
dixonk's Avatar
dixonk
St. Jude Donor '09
As long as you go with a big pulley on the head unit and get a nice size crank pulley you should be able to drop the boost down quite a bit and then run it with the compression you have and the cam you have. I would say you could probably safely run 7 psi on a good tune and make power with minimal effort that way. When I had my D1 I was running 650 rwhp on stock bottom end and stock rod bolts and never grenaded it. But then again my tune was SPOT on!
To Procharge or Not
