Heater pipes against firewall
Old Oct 16, 2008 | 07:05 AM
Rascal2U's Avatar
Rascal2U
6th Gear
Default Heater pipes against firewall
hi guys, my 97 C5 has sprung a leak at the back of the intake manifold on the heater pipe where it goes through the firewall on the drivers side. How do i get to these pipes??
Old Oct 16, 2008 | 12:19 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Removing the intake and driver side head will give you access.
Old Oct 16, 2008 | 10:46 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep! Intake manifold at a minimum. Not a big deal. HOW the hell did it spring a leak????
I have some pictures of that area exposed at home. Ill post them after work!
Old Oct 17, 2008 | 07:46 AM
Rascal2U's Avatar
Rascal2U
6th Gear
Thanks guys, removed the intake manifold and found that the water pipe (thin one which has 4 bolts into block) which sits under the intake manifold was leaking and NOT the heater pipes as thought. One of the bolts (drivers side) had worked itself loose and water was leaking from there. Thanks for the help Bill and Blown
To Heater pipes against firewall
