Fuel Additives
Old Oct 18, 2008 | 10:19 AM
jovette's Avatar
jovette
Originally Posted by samsvette
Thanks, also for winter storage do I
A.) Full tank (to prevent condensation) with Sta-Bil
B.) Empty tank (to prevent using old fuel)
When should I start the car in winter once a week, every two weeks, or once a month?
Don't start the engine at all during the winter..............unless you are going to take the care out and drivie it long enough to fully warm the engine oil and burn off any condensation in the crankcase.........better to just let her sit, a hook up a batter tender until you take her out in the spring.
Old Oct 18, 2008 | 01:40 PM
samsvette's Avatar
samsvette
Default Fuel Additives
Don't start it at all during winter? I planned on starting it, letting it sit and idle in the garage until it got up to temperature about once a month. Also should I keep a full tank of gas or a nearly empty tank, I'm in Louisville KY and we'll get below freezing temps in the winter
Old Oct 19, 2008 | 02:45 PM
j84buick's Avatar
j84buick
Originally Posted by jdhommert
Nothign more than a genious marketing scheme run by quick trip.
QT even owns that website.
Samsvette - you hijacked the thread but your new so it's ok... lot's of threads on CF discussing this. I am start every 6 weeks guy myself. No debate on this issue: full tank!
Old Oct 19, 2008 | 11:51 PM
2003 electronblue's Avatar
2003 electronblue
i use stp every other tank along with the stp water remover [from gastank] [red bottle] no problems.
Old Oct 20, 2008 | 08:37 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I have always kept the gas tanks full in my cars when they sit for prolonged periods in the winter. You will get less moisture in the tank that way. Also, driving the car as weather allows periodically is the best way to keep everything working properly. There's always a few days even in the Northeast when the roads are clear and dry. Never used Stabil. I don't consider 3 or 4 months to be long term storage. If you can drive it enough to top off the gas a couple of times a winter you don't need Stabil.
Old Oct 20, 2008 | 08:46 AM
TDS00PET's Avatar
TDS00PET
I use sea foam especially during the winter in all my vehicles. When the vett sits for long periods of time in the winter, I believe it helps keep the water out of the system and cleans the systems. The vett sits much of the winter but I do try and let it run every couple of weeks for at least 10 to 15 min, and if it's a good day, we take it for a long ride.
