Where is the drivers side headlight relay?
Old Oct 17, 2008 | 06:04 PM
rockgoped's Avatar
rockgoped
Default Where is the drivers side headlight relay?
where is the relay for the driver headlight? headlight wont pop up. checked fuses and connections.
Old Oct 17, 2008 | 06:26 PM
byronhunter's Avatar
byronhunter
Give me your Email address, I'll send you a wireing schematic of the headlamp actuators. --- byronhunter@hotmail.com
Old Oct 17, 2008 | 06:37 PM
rockgoped's Avatar
rockgoped
viper3056@comcast.net
Old Oct 18, 2008 | 03:47 PM
lionelhutz's Avatar
lionelhutz
Did you try turning the manual **** under the hood until the motor was turning loose and then turn on the headlights? If that lets it pop up then you have a gear going bad.
There are no relays per say. The motor controller is under the passenger side headlight.
Peter
Old Oct 18, 2008 | 06:05 PM
rockgoped's Avatar
rockgoped
its not a gear problem i know for sure. its a electical/signal problem. you think its the control module for the headlights?
To Where is the drivers side headlight relay?
