Nitrous question about tps
Old Jan 10, 2002 | 03:27 PM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
Default Nitrous question about tps
Hooking up a NX Throttle position activation switch(TPAS) it should hook in to the cars output signal on the TPS to the computer.
Is it the brown wire or yellow? :confused:
Old Jan 10, 2002 | 04:48 PM
jetskifast's Avatar
jetskifast
Default Re: Nitrous question about tps (iceburgh68)
On passenger side of TPS you will see 5 or six wires. TPS N20 activation switch will hook up to Dark blue wire. Installed BPP N20 activation switch on 2000 and 2001 C5's. Other years may be different.
Old Jan 10, 2002 | 05:58 PM
intel55's Avatar
intel55
Like Jetskit said it is the Dark Blue wire on the passenger side tps cpnnector. It is connector pin C, dark blue :D :cheers:
your pic is the tac module, the other side has the tps sensor.
[Modified by intel55, 3:59 PM 1/10/2002]
Old Jan 10, 2002 | 07:14 PM
iceburgh's Avatar
iceburgh
unless I am looking at the wrong area....I only see two wires one is brown and the other is yellow both come in from the passengers side and plug in as seen above??????
Am I looking at the wrong thing????
Old Jan 10, 2002 | 08:35 PM
jetskifast's Avatar
jetskifast
As intel55 pointed out. Your picture is of tac module. Look on other side and you will see connector with five or six colored wires. Dark blue is what you want.
Old Jan 11, 2002 | 08:46 AM
iceburgh's Avatar
iceburgh
You guys are life savers.........Thanks :D :D
To Nitrous question about tps
