Wiper problem
Old Oct 18, 2008 | 08:08 PM
drus1957's Avatar
drus1957
1st Gear
Default Wiper problem
The wipers on my '02 have been turning on by themselves. I have been able to get them to stop by using the washers & then they would turn off. Today, however I had to pull the fuse to get them to stop. Any help would be appreciated.
Old Oct 19, 2008 | 05:58 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The wiper motor control module is on the bottom of the motor and sits in a well. The well has THREE drains that frequently get clogged. If it gets clogged, the wipers can and do flip out.
Heres where the udders are that get clogged:
You can reach them here:
Here is what came out of mine!
Clean those udders and hopefully the controller will dry out and reurn to normal.
BC
Old Oct 19, 2008 | 11:35 AM
c5blkvetteguy's Avatar
c5blkvetteguy
I had the same issue. Even after I cleaned the udders the problem was still there. Good luck with yours. I had to replace the motor. If you do this yourself, be extra careful when pulling the wiper arms off. Also, make sure the cam on top of the motor is in the right position.
Old Oct 19, 2008 | 12:26 PM
jabrun's Avatar
jabrun
I agree with what the others have said, my buddy had the same problem and the circuit board was wet.
To Wiper problem
